    Aug 2011
    Kirkham
    11
    ESP warning light when cold only
    Hi all,
    I am new to this forum, been reading it a bit for a while and love all the useful infos on here.
    I have a 2001 A3 1.9 tdi 130.
    Started 2 weeks ago, when the car is cold. Start it, go out then within 1-2 min, the car rattles, steering wheel shakes and the ESP warning light comes on. I switch off the car (even while driving), start it back and I'm all good, no more problems til the next cold start.
    Started after I got new number plates fitted, screwed/drilled ones, probably a coincidence. Left the car in that garage over lunch to have it done, bit worried they tempered with it to get another customer coming back.
    Any help will be greatly appreciated.
    Aug 2011
    Kirkham
    11
    Hello again,
    I managed to pass it on VCDS for faults, here the results:
    Address 01: Engine Labels: 038-906-019-ASZ.lbl
    Part No: 038 906 019 CK
    Component: 1,9l R4 EDC 0000SG 1477
    Coding: 00002
    Shop #: WSC 06435
    VCID: 62CE0A23C4DF
    WAUZZZ8L62A012745 AUZ5Z0A6260042
    2 Faults Found:
    18075 - PD Unit Injector; Cylinder 2 (N241): Electrical Malfunction
    P1667 - 35-10 - - - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 E
    Component: ESP FRONT MK60 0104
    Coding: 0019970
    Shop #: WSC 06435 000 00000
    VCID: 2C52A41BF32E
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    008 - Implausible Signal - Intermittent
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Now it starts to do it more frequently, still only when engine is cold and disappear after 2-3 min and re-starting 3-4 times
    I've checked all electrical cables without unplugging them and they seem fine.
