EM TuningJMB Retrofits
Results 1 to 19 of 19
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Exclamation What A Pain In The A** :-(
    I've not been well but thought i would take the O.H and kids out.
    On my way back (about 50 miles from home) the air con kept going off then coming back on again. While I'm thinking “i only had that done about a week ago” there's a loud beep in the car and i get a warning on the DIS.
    The car temps then climb to almost max. So i pulled over asap and popped the bonnet expecting to see coolant everywhere but everything was dry and the coolant level was spot on. I then noticed that the fans weren't coming on so started checking all the fuses (thanks to the sh*t diag on the fuse box cover) in the fuse box and the one on top of the battery, but they where all ok.
    The next step was to call the breakdown company that kept me waiting for 2 hours.
    When he showed up, he said “your coolants a bit low” and fills it up to the top of the bottle (ignoring the max markings about halfway down the bottle) he then tried to get the fuse out from the box on top the the battery. The fuse was like it had been welded in but with a bit of brute force he managed to get it out, This is what it looked like:
    So he put a new fuse in and all was well. He then said that the circuit board on the holder is probably fu*cked and that's what's arcing and made the fuse weld itself in.
    Has anyone heard of this?
    Then about 10 miles from where i over heated , i get this symbol on the dash:
    So thought great now i need new pads, but when i got home i had a good look and the discs look like they have quite a big lip round the edge so it looks like ill need new discs as well
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Nov 2008
    154
    That fuse on top the battery often does that, comon issue.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by A3 T View Post
    ...he then tried to get the fuse out from the box on top the the battery. The fuse was like it had been welded in but with a bit of brute force he managed to get it out, This is what it looked like:
    Has anyone heard of this?....
    Very common... has been know to start an engine fire too... I had the same issue...
    My minor modding thread
    <tuffty/>
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Thanks guys
    <tuffty/>
    Is there anything that's not in that thread....lol
    I found this link last night:
    http://forums.tdiclub.com/showthread.php?t=242699
    So today i started the engine and put the air con on low with the blower on one line......
    Both fans come on but they both seemed like they were spinning fast.
    Is this what their like on the a3 or is there a fault?
    Also i had a look at the brakes in the day light and the discs don't actually look that bad and there's loads of meat left on the pads
    could this be a sensor fault as the warning on the dash isn't always there ?
    AJC
    AJC's Avatar
    Surrey
    172
    Yes happened on mine as well. New fuse and all's well and saved a potential large bill to fix the air con. I ended up buying a new circuit board from Audi as I didn't want the risk of a fire. At least your's didn't catch fire!! There's always a bright side eh?
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    Those stupid brake sensors are practically in the middle of the pad so they do come on quite early so no real need to start panicking and booking the car in for a brake change straight away UNLESS you like drive like a lunatic every day.
    With the mileage I do, it was a year later when I replaced mine ! I use a secondary rule - look at them with my eyes.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by AndyC-S3 View Post
    Do you know if both your fans spin fast or slow when you first turn on the air con (after you fixed everything....lol) ?
    Quote Originally Posted by thegoal007 View Post
    I thought at first but I've been reading that the sensor is a wire that gets broken when the pads have worn, so the dis warning should stay on until the pads are replaced....
    The strange thing with mine is that the warning doesn't come on until I've been driving for a good few miles.
    AJC
    AJC's Avatar
    Surrey
    172
    With the engine running, air con off and engine temp cool the fans are naturally off, as you turn the air con on both fans spin up fast. Hope that helps?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Thanks mate
    Hmmm.....
    So why does this troubleshooter say they should start slow:
    thegoal007's Avatar
    Apr 2008
    surrey
    729
    That's exactly right right, but why yours is not coming on every time you start the car is strange. dodgy sensor, wiring, (are fuses involved in this mechanism ?). Mine would bleep every time i started the car for a year until I replaced the brakes.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    I've been doing a bit more reading and the fans should have two speeds. when the the air-con is first turned on they should come on slow and then after a few seconds speed up.
    It seems that the reason behind the fuse burning up is due to the fans always being on at high speeds.
    So maybe you should also have your fans checked out
    Hmmm....
    Thanks mate, I think ill check the sensor connection
    AJC
    AJC's Avatar
    Surrey
    172
    I've read through that thread and my fans operate exactly as read but thanks anyway.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    That's good mate
    So yours come on slow then?
    AJC
    AJC's Avatar
    Surrey
    172
    That's good mate
    Yes for about a minute and then speed up. I was told a common problem with the air con is the compressor blades can stick and consequently burns the fuse out as per your pics.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Mine seem to be fast from the start
    Also i did about a 6 mile journey today without any brake pad warning, but on my way come i had to brake a bit sharp and the warning come back on. once the warning comes on it stays on until i turn the engine off and isn't their when i start it back up
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    .....................Also i had a look at the brakes in the day light and the discs don't actually look that bad and there's loads of meat left on the pads
    It could be that the socket where the sensor plugs into is broken or loose. Seen a lot of VW's where the plug breaks. New wiring loom for VW is approx £30 - £40 from dealer. Should be the same for Audi.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by SL11 CKK View Post
    I'm going to check it as soon as i can (I'm not in the best shape myself at the moment...lol)
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Brake pad light is coming on as soon as i turn the ignition on now
    Would this be a good guide on replacing them (the guide if for the a4)?
    http://audi-diy.blogspot.com/2007/10/how-to-replace-audi-a4-brake-pads-and.html
    Does anyone know where this black cable goes?
    I felt it today after the car had been at idle for a while with the air-con on and it was really hot
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
