Sky InsuranceJMB Retrofits
Results 1 to 20 of 20
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    1.8T Sump Gasket
    Oil Pan Gasket 06A 103 609 C AUDI / SEAT / SKODA / VOLKSWAGEN
    Has anyone on here used one. I have to change the pickup on mine for piece of mind and didn't want to have troubles getting a good seal. This might work quite well? Looks like there's an OEM VW part number too.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I thought it was just sealant, never seen a gasket for one...
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    Yeh it is supposed to be sealent on there. But i think it should work just as well. all the bolt holes are all close together so its unlikly it would blow out or anything stupid
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    I know the norm is to use sealant but I want a solution which is going to guarantee a non leaking sump! I've done a few before and they're always a pain with pure sealant. I'll give VW a bell in a bit and see what it costs and if they can get it...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    VAG sealant is the best stuff.... never had any leaks on any sump I have done using the stuff... use the stuff on mine... never leaked... not even a weep..
    <tuffty>
    Jun 2011
    12
    I agree with the above comment. I've done around 3 now with the Vag sealant. Works great
    2000 Audi S3
    1990 Golf Mk2 G60 Syncro
    1969 Karmann Ghia
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Alright well I'll give it a go. I was just looking for an easy way out. I have bought the proper VW sealant (renzosil). I guess a standard bead around the inside of the bolt holes is enough then?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by Sam_ View Post
    Yes that will do it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Seeing as I was fititng a sump today I thought I would take a few pics to help out...
    Thin bead of sealant in the center of the flange going round the inside of the bolt holes...
    ...when bolted up the sealant will squeeze out... if you use too much then it will be doing the same on the inside as the outside... this could break off and float around the sump so make sure not too over do it...
    ...the two inner bolts on the gearbox side of the sump are a git to get too as they are offset from the access hole...
    I use a 5mm ball ended allen key (in this case a 3/8 rachet) to start the bolt in using a blob of grease on the end to prevent the bolt from falling off then do it up using a 1/4 wobble extension and 10mm socket as the 5mm allen key can round...
    ...and there we have one 'sealed' sump
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Awesome thanks for that mate. I'll be doing this soon to replace my pickup. It's been serviced very regularly but can't do any harm.
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    I used Loctite Flange sealant when fitting my sump, Worked a treat and fitted a sump to a transit connect with the same stuff and worked great.
    Black S3
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    i wouldnt use anything other than the VW sealant. (cant remember my last tube being called renzosil)
    However, i have never had one leak on me.
    *Also nice sumpy tuffty, yours baffeled?.
    Dubstep's Avatar
    Jun 2011
    Somerset
    53
    Ill be dropping my sump shortly to change the pickup pipe and give it a good clean, very tempted to take it to a local metal fab to have it baffled.
    Audi S3 APY.
    Man needs god like a fish needs a bicyle.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by MrCSW View Post
    Not mine sadly... was fitting that one to a customers car...
    <tuffty/>
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    also snap-on do a lovely 6" long 5mm ball ended allen key (3/8"dr) which makes the two awekward bolts a doddle.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Any decent branded sealent does the trick, as tufty says dont overdo it it ...less is more....
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Well this is made by Victor Reinz, the OE gasket manufacturer if I'm not mistaken? It says "approved for all european and japanese vehicles, eg. .... VAG" and it's the right stuff by the looks of it.
    Do you guys let it partially cure before for a few minutes or whack it straight on?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    straight on sam......
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    straight on as said then i was told/read to leave it for 40 mins before adding the oil to allow the sealant to bed without coming in contact with the oil
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    I'll be leaving the oil out of the engine overnight while it cures anyway...
