Volks AutosJMB Retrofits
    Jul 2011
    Unhappy Very Poorly 1999 S3 Please HELP!!!
    Hi,
    I bought myself a bargain buy S3 knowing full well it was a bit of a shed.
    Low and behold a month after its on it backside.
    i thought it was the throttle actuator so i changed the throttle body and it hasnt solved the problem....
    symptoms
    Lack of power (total at times)
    hunting
    cutting out
    occasional backfire only slight tho
    now im told that if you change the throttle body you have to have it re calibrated.....is this true? isit a vagcom job?
    does anyone have any ideas?
    please help
    steve
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Do you have Vagcom/VCDS? If so, what sort of fault codes is it showing? That'll give you a good idea of what's up. I haven't experienced that (touch wood) but the common issues which could be related are:
    - Tired MAF
    - Boost/vacuum leaks
    TBA (Throttle Body Alignment) is also done in VCDS. I'm not sure I've read of many issues related to the throttle body though...
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Is it backfiring through the intake or exhaust?
    KB
    KB's Avatar
    Jul 2010
    Inverurie, Aberdeenshire, United Kingdom
    195
    check all your vac pipes, i have a 99 apy, and loads of my vac pipes were split and hanging to bits! plus check the vac hose coming off your servo
    Nov 2008
    154
    Agreed it sounds like intake system or vacuum system leaks, get poking around for split hoses. I drove a mondeo with similar problems (non-turbo) and i left it running and starting pulling and poking around under the bonnet until the engine sound changed and that helped me find the split hose.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    738
    Things to check as aready mentioned are Vac leaks, boost leaks, MAF (un-plug and see if it runs bettter, if so then it is the MAF) Coil packs. VAG-COM really is essential for trying to do any serious diagnostics as without you are poking around in the dark.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
