EM TuningAH Fabrications
    Ginge's Avatar
    It's never fast enough !
    Jan 2011
    Hemel Hempstead (home) / Loughborough (UNI)
    192
    Haldex pre pump help please
    When I turn the ignition on you can hear the pump whirring, however it kind of unevenly pulses rather than a constant whirr.
    I'm having problems with my haldex at the moment, something that a new controller did not fix so I am trying to find a different solution to the problem.
    Thanks for any help guys
    99' S3 APY currently just 007p, Badger 5 TIP, Customised Miltek non-res cat-back, Jetex cone, H&R Springs and Bilstein B8 Dampers ... 3" Downpipe, AH Fabrications FMIC and R-Tech Re-map on the way
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Like a repetative buzz click buzz click buzzz?
    And youve replaced the controller too???
    What faults are you getting??
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Ginge's Avatar
    Jan 2011
    192
    Yeah its repetitive but not regularly, so the buzzes and pauses are different lengths to each other. I have no 4wd at all and I get fault code that means no communication to haldex controller (think it is 01324 but can't 100% remember).
    I have also checked all the cables to the controller with no corrosion.
    I am now thinking that the controller I bought in working condition may not have been working OR maybe earthing strap ( which i forgot to check, or pre-charge pump or .... maybe it needs and oil and filter change ?? there was a tablespoon of oil that leaked when i changed the controller and it was as new, no buts or discolouration so I am officially stuck.
