Badger5JMB Retrofits
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    buzzing noise....help needed please
    just been doing some work on my car fitting a forge tip.
    started the car, turned it off and the little electic component fixed right infront of the fan is buzzing, is this normal? ive heard it a few times but never stayed on after ignition off and car locked??
    i think its the aux water pump...
    have i pic ive found on the web of what it is.....
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Yes its a water after run pump to help cool things down. |It should stay on for a while after the engine is hot but wont stay on long if you only started the car and then turned it off
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Inertiauk's Avatar
    Mar 2011
    529
    You are lucky, yours works :-)
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Ive just changed mine for a trusty omega one, works spot on now...
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    yeah car wasn hot. hadnt been started all day and then was only on for like 30 seconds. just worried it shouldnt of been on. but guess i cant complain if it is working.
    just i finished work the other week and come back to a flat battery. checked everything and it was all off. so either fan or something stayed on until battery was completely drained.
    thought it may of been this.
    thanks for the replies
