Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    Sep 2010
    Devon
    752
    4motion brakes on an A3....
    Hi all,
    I'm looking for some brake advice, I know there is lots of threads on this but I couldn't find anything on this in particular... I need to upgrade my brakes, should have done already really, I am looking at putting some 4motion brakes on my 1.8 T, I would love to put on LCR Brembos but I don't have enough cash especially as I'm doing the suspension at the same time....
    Any advice from you knowledgable folks would be greatly appreciated, thanks in advance
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    I'v got a S3 set up for sale if that any good to you?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Sep 2010
    Devon
    752
    Yeah, that would have to be an improvment on mine. Doesn't everyone with S3's upgrade theirs though? I only ask as mines running 228bhp so Im worried about upgrading to something which won't make to much difference. PM me and I'll see!
    Inertiauk's Avatar
    Mar 2011
    529
    That's similar power to a standard S3, the brakes are really good on standard S3's will suite yours well.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    I would have thought the 4 motion stuff was similar to the A3 Quattro stuff... which is pants so the S3 would be a better option
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    428
    I thought the 4 motion brakes were the same as s3?
    Inertiauk's Avatar
    Mar 2011
    529
    Quote Originally Posted by Lee172 View Post
    Disc size is, but I 'think' callipers differ.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,069
    The 4 mo uses 312's up front, and 256's at the back. exactly the same as the S3
    the calipers are no different at all.
    A3's and S3's have identical calipers. to upgrade from your standard 288mm brakes, all you need is new discs and caliper carriers. you retain your original calipers.
    Standard S3 brakes are NOT any good on an S3. they're rubbish and prone to fade. This is mainly due to the weight of the S3 though.
    Fitting 312mm S3/4mo brakes to an A3 is a fairly good upgrade. because the A3 is so much lighter than the S3 they're actually pretty good, and will stop it fairly well.
    they're still no good for track use though, but on a road car, more than enough.
    256mm 4mo rears are also a good upgrade, but not 'quite' a bolt on mod like the fronts.
    Sep 2010
    Devon
    752
    The main thing I'm trying to cure is fade, I live in Devon, all up-down twisty turny, great fun til your brakes fade. Is the 312mm upgrade likely to make a noticable difference to this? Maybe I should skip the suspension for a bit and just do the LCR's....
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,069
    Do you experience bad fade on your current setup? I'm guessing you probably do!
    the 312's are much better, but will still fade when pushed and heated up loads.
    Even with LCR brakes you're going to need really good pads to avoid fade.
    I run DS3000's, and they don't fade, ever.
    Sep 2010
    Devon
    752
    Plenty enough fade! Yeah every knowledgable person I speak to says ferodo pads all the way..... Just spent a little spare cash doing up the front of my car so now I'd like to keep it looking realitvely pretty!
