Badger5AH Fabrications
Results 1 to 17 of 17
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    Question 18 x 9.5" ET15... Possible on an S3?
    As the title states. I've been offered a set of wheels in 18 x 9.5" ET15 5x114.3 stud pattern.
    Would it be possible to fit these in anyway, shape, or form?
    Cheers gents,
    Ryan
    '02 Audi S3 - 270bhp / 283lb ft - SOLD
    '08 BMW 135i - 306bhp / 295lb ft
    '12 VW Golf GTD 170 - 168bhp / 258lb ft
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I'd say no. You're going to need adapters, the minimum thickness of which would be 15mm making the wheels ET0. At that offset, they'll be sticking out an extra 50-60mm over the standard wheels (not 100% on the width and offset of standard).
    They *might* fit but I'd say no. Hopefully someone else can shed some light. 9.5" isn't a problem on the rear from what I can see but it's the offset that's the problem.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Sep 2010
    207
    I very much doubt they will fit. U need a higher offset for adapters. Plus the 15mm adapters are not all that safe. Minimum id go for is 20mm and probably h&r!
    Other option is major camber nd major stretched tyres... Then they might sit in the arches, but it will handle like a boat!!
    A3 1.8t facelift 150p, milltek catback, forge 007p, gloss black roof, black s3 spoiler
    next on the list is some wietec coilies and eibach arbs front &rear
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Quote Originally Posted by Jordan1.8t View Post
    This is based on what? I've done a fair amount of research and not seen an issue, only people "saying" that they're not safe (who usually have no experience with them). The guy that built my adapters has been building them for 10+ years and said there's no issues with 15mm adapters but demanded they were hub centric (I asked anyway). H&R also make 15mm adapters and I'm pretty sure they are TUV approved. If the adapters are built from the proper materials and to the correct tolerances you'll have no issues.
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    Gutted... The wheels are amazing and weight f-all...
    Oh well, the search continues for some genuine BBS CH's or something else that tickles my fancy.
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    Gents...
    Would it be possible to get some new hubs made up in 5x114? Just thinking how much it'd cost since I can get the wheels cheep.
    So in theory, 18x9.5 ET15 with 225/235 tyres. Would they fit or would they still catch the arches?
    Cheers,
    Ryan
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    orrrr, get the wheels skimmed and machined down to higher the offset so you can run the adapters. iff you reaaaallly want them
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    I've sent an email to a company in Germany who make custom hubs... Will see what price they come back with.
    Theirs always the option of redrilling the standard hubs to fit 5x114.3 (which will work fine on a 5x100 hub... apparently). Not too sure about stress levels on the hub itself though...
    Hmmmmmm.......
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Quote Originally Posted by Ryan_W View Post
    Gents...
    Cheers,
    Ryan
    In short ET15 with an 8.5" rim is tight, so 9.5" is going to look stupid, with adaptors, it's going to be ET0 which is no chance at all in my opinion.
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Wel mine are et 50 11j on the rear,with 30mm adapters so thats et 20!,i have had arch's rolled 25mm on the rear with 235,35,19 tyres,did take alot of work and handles amazing,it does scrub a little but thats because i like alot of pos camber and its only slightly rubbing the arch liner! Anything will fit you just need time and money!,hope this helps!
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I put some pics up of my wheels fitted here:
    My S3 Thread
    Basically 18x8.5 BBS CH with ET15 rear, ET20 front and they are almost flush with the arch. Could probably do ET10 on the rear.
    I found this site handy for measuring up:
    Wheel Offset Calculator
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    there's no way these will fit! the rears could go on at a stretch.. but by the time you have adapters in there minimum of 15mm so your be running a et0 wheel on 9.5j......
    i run et12 on 9j at rear you could run et0 9.5j probably but you'd have a lot of poke. my wheels sit flush with the arches.
    but front i run et27 on 9j so an et0 and 9.5j wont work for sure you'd need some wheel arch extensions or somthing but will cost a lot is it worth it??
    front your be running 33mm poke and rear will be 18mm poke
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Quote Originally Posted by s3_kev View Post
    This is what I've been trying to say in my last few posts, but not in so much detail. If the wheels are 9.5" wide all round, you have to get the issue of clearing the front wheelarches before even considering about the rears.
    They won't fit basically - Simples!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Yep, also see post #2
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    I put a set of front 9.5js on my mates s3 et 30!,just about went on 215,35,18 tyres!,with a lower et be hard but if its not to low with arches rolled 30mm might just be ok!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    My fronts are et 10 215,35,19 8.5j
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Sorry mine are et12!,his are et15 so would be close but thats what gives the stance id say go for it!,would take some work though!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
