Sky InsuranceAH Fabrications
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Karl-g
Thread: Stumped! Hope its not the timing chain!
    May 2011
    London
    11
    Hi all, bought my 1.8t two months, ago its a 2001 with just 56000 on the clock, about a week after, the engine management light popped on, VAG tells me the following.
    17748 - Camshaft Position Sensor (g40)/Engine speed sensor (g28)
    P1340 - 35-00 - -
    After reset on vag, I drove for half an hour and all was fine. Then the next morning on starting, the engine management light pop up! I have reset a few times to see if there was a pattern developing and it seems to only happen when I first start the engine? I have just yesterday changed the oil and am keeping my fingers crossed its dirty oil slowing the pressurisation of the engine, could this be possible? Really hoping it’s not the cam chain or tensioner, pretty pricy! I have read that it could be the sensors or as little as the timing belt being off by a tooth but I’m confused by the fact that the fault is only thrown at start-up?
    Any ideas would be a great help,
    Many thanks, must pop a few pics up soon, stealth A3 8L on the way!
    Karl
    BENJAMIN's Avatar
    Mar 2011
    460
    I've seen this code a couple of times where the cambelt has been fitted a tooth (or 2!!) out. Check this first dude, before looking at other possibilities.
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    I agree with benjamin, had same problem after a water pump and cam belt change. Have only seen one 1.8t that had a stretched timing chain and but it was un drivable.
    May 2011
    London
    11
    Cheers guys, will check this asap. have used the car all weekend since the oil change, no engine light yet, fingers crossed!
    Inertiauk likes this.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    All of the 1.8's have timing belts, not chains btw.
    ...... Waiting Paitently...
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Quote Originally Posted by S4quatt View Post
    They have both. A belt to drive the exhaust cam and a chain to drive the inlet cam from the exhaust cam
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    564
    Now you're just picking at straws lol!
