JMB RetrofitsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 43
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Fault Diagnosis time.... (We all love this)
    OK, so let me give you the basics...
    Loud humming, grindy sound which gets worse with speed. Definitely a rotational noise.
    Minorly affected by turning whilst driving. Not affected at all by dipping clutch, coming out of gear etc etc. If the wheels are doing over X speed, then she's humming.
    Naturally, you would think wheel bearing, as I did. But it's not. Just changed the bearing yesterday and refitted to find the noise worse than before....
    I know what I think it is, well, one of three possibilities. I just wanted other opinions....
    Discuss.
    Homer Simpson
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Discuss.
    CV joint perhaps? Driveshaft?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DaveA3 View Post
    Interesting... Based on symptoms, which CV would you think, inner or outer?
    Homer Simpson
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Have you checked the brake discs/pads for strang wear patterns?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Eenie meenie... Outer!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by W3STY View Post
    Yeah, but nothing unusual there. Brakes are old, and do need replacing however they shouldn't be causing the sort of din I can hear.
    Quote Originally Posted by Dane View Post
    Hmmmm, 50% chance = no chance. It's more likely to be the inner I think...
    If it is the inner CV though, I suspect it will fall apart upon removal, judging by the noise it's making.
    Failing that, it could be an out of shape tyre, or the box.
    Homer Simpson
    Dane's Avatar
    Cheltenham
    4,003
    Anything obvious on the propshaft? downpipe rubbing or anything?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Not that I could see, that is however, a good point.
    I must admit it doesn't feel like it's coming from that area, but I shall have a look none the less...
    It would be sooooo easy to find on a ramp me thinks. All you would have to do is knock it into gear and drive it to like 40 mph in the air.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,280
    Diff/haldex?
    S3 Build Thread
    Dane's Avatar
    Cheltenham
    4,003
    Nah that would be obviously coming from the back
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    get under it and wiggle some of that TT drive shaft, see if there is play.
    I'd go for CV joint and i'd opt for outer as well, since its happening when turning.
    Whats the 3 possibilities?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Diff/haldex?
    Nope, deffo front.
    Messing about with the driveshaft to remove and refit the hub has made it worse which makes me think a CV joint is a possibility (as it's been disturbed).
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,280
    Nope, deffo front.
    No visible splits in the CVs? grease caked everywhere?
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by ScottB5 View Post
    It's not just happening when turning dude, it's happening all the time. Turning, straight, simply all the time.
    I mean this noise/vibration is enough to make the dash rattle at 50 mph...
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Over looked good. Inner did have a small amount of grease when I put my hand down there, but I didn't inspect as I was sure it was the bearing!! lol
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I reckon that (in order of likelihood):
    1) Inner CV joint
    2) Gearbox
    3) Out of shape tyre
    Homer Simpson
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    Sounds a bit like a tyre fault.
    jack one side up and check the tyre.
    when you're at it check for any other play or movement.
    I had a bad tyre on my A4 and it caused vibrations enough to make the satnav unreadable.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK, that's useful to know. I guess the easy test is to swap wheel front to back on the driver's side.
    Ten min test.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,280
    Try your S3 wheels on the TT mate. Might be wheel balancing issue?
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I don't think so mate, not with the level of noise it produces. Yes, vibration, but wheel balancing producing noise??
    Out of shape tyres make a right din though.
    Homer Simpson
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    I hate out of shape tyres.
    Bought a set for the pug just before the MOT, nasty little rumble/whine, MOT guy advised me of a out of shape tyre, went back to tyre place and 2 new tyres fitted and balance. car drove and sounded so much nice.
    and like you said, its only a 10min job and you can check other possible faults at the same time.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Whilst I agree, and out of shape tyres are a pain, the volume of the noise being created is mad. I would expect the tyre to be square.
    It is VERY loud.
    Homer Simpson
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Can you get a video of it?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Lee172 View Post
    Yup, I think I will later on just so that everyone can hear it. It's easier than trying to describe it.
    Homer Simpson
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    outer (wheel side) if its on steering slightly. Any splits or anything on inner or outer?
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    I always thought outer cv's tend to make clicking noises when they're on the way out.
  28. #27
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I guess I didn't explain very well. It's ALL the time, but the sound is altered very slightly by steering wheel adjustment. Only a slight change in the pitch.
    Homer Simpson
  29. #28
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yeah, outers are easy to diagnose. Reverse in a tight circle and listen.
    Homer Simpson
  30. #29
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    Welly, I found a solution to your clunk and rumble
    I'll got back to the pub.
  31. #30
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    lol, the amount of time I said that about the S3....
    Homer Simpson
  32. #31
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I reckon it could be 2 things
    1. Dodgy tyre as mentioned
    2. Power steering fluid ok?? Possible that the steering rack is leaking on the seals??? (you won't have any visible sign of fluid on the floor )
  33. #32
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    now i see why it could be inner.
    Also following the tyre thing sandip said above are the balancing plates still on there? Ive had some come off in the past that completely ****ed up everything
  34. #33
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I didn't really look at much else to be fair as I thought it was the wheel bearing.... D'oh.
    Homer Simpson
  35. #34
    Westy's Avatar
    Dec 2008
    17,280
    Well, I think you should come back once you've checked the car properly
    S3 Build Thread
  36. #35
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Guilty as charged.... lol.
    Homer Simpson
  37. #36
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    As the bearing gone in squarley, may be you damaged it putting it in?
  38. #37
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I didn't press it mate, I got my local VW Audi specialist (well, my mate who works there) to do it for me and bring it back.
    He said it all went in fine with no problems.
    Homer Simpson
  39. #38
    May 2011
    Sunny South wales
    82
    Could it be the bearing on the opposite side ? I've been caught out before, sometimes noise carries across axles.
  40. #39
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    I have a really annoying squeaking noise from my passenger side wheel so be interested to see what cures your noise.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
  41. #40
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    Quote Originally Posted by antwan View Post
    I'd be checking this. Its usually fairly obvious when its that far gone though simply by spinning each wheel and seeing which sounds rough.
    TD5 Land Rover Defender build
