EM TuningAH Fabrications
    A.M.K S3 ANT's Avatar
    Jul 2011
    Rotherham
    fuel pump s3 2001
    hey guys,
    keep having a recuring problem with the fuel pump starting up 9/10 relay kicks in on ignition, on odd occassion it won't. AA guy came out and tapped under fuel tank/pump then it kicks in on ignition will not turn over untill i tap it.... any ideas if its a new fuel pump needed or something seperate?????
    Any ideas please let me know thanks.............
    Sep 2010
    Teesside
    31
    Hi mate did you ever get to the bottom of this fault as mine now has the same problem.
