JMB RetrofitsEM Tuning
Thread: Dodgy MAF?
    Jul 2011
    South Wales
    Unhappy Dodgy MAF?
    Hi guys, having a bit of trouble with my a3, wonder if anyone can help...
    Car was running fine up until a few days ago. parked it up late at night and all was well, when i started car the next afternoon, the Engine spluttered a bit on tick-over and Stalled... Restarted and Engine wouldn't run without keeping the revs up, even with the revs up it was misfiring a little.
    Anyway, i suspected the MAF, as i have not long ago changed the plugs (i felt the car was down on power a little) and the leads/coils appear to be in good condition (cant tell too much visually i know) so i unplugged the MAF.
    With the MAF unplugged the car runs fine alas very rich with a very flat powerband, I did a bit of digging and im assuming this is just a baseline map the ECU reverts to with the sensor unplugged, I Tried giving the MAF a clean in iso-alcohol with no joy, as soon as i plug the MAF in the car splutters and cuts out again, all connections seem fine with no oxidisation.
    It would appear that i have found the problem, but i just wanted to check if theres any other variables i should take into account before swapping the MAF as im a bit short on cash at the moment! haha
    Any Help Appreciated
    Joe
    Apr 2010
    Widnes Cheshire
    404
    Yeah sounds like the MAF has gone walkies, but get someone with VAG-Com (VCDS) to read any error codes first, before buying a new MAF.
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
    Jul 2011
    South Wales
    Thanks for the reply Den, Il do just that!
    Joe
Tags for this Thread
