EM TuningJMB Retrofits
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Testing for boost leaks
    I would like to know how I can test my engine for boost leaks?
    Im aware that some members have fabricated tools to test for leaks, but can I buy these tools from anywhere?? Or would anyone be kind enough to lend/rent some to me??
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Feb 2008
    Manchester
    158
    very interested in this too
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    There are various options, you can get a compressor and do a boost leak that way, alternatively you can do a smoke test.
    Your best bet is to take it to take it to a specialist that already has all the tools...or someone locally you know.
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Thanks for the advice Nilz, I have been searching the web and there are some guides on how to DIY.
    Some interesting methods being used, I think im going to give this way a go;
    1, Remove air filter, Maf and plug that hole
    2, Remove N75 and plug hole with a tyre valve
    3, Use mole grips to close pipe going from hockey puck to tip
    4, Connect air compresor to tyre valve and run 20 PSI into system
    5, Listen for leaks, and if need be put soapy water round joins to show any leaks.
    This sound ok to do, or am I missing anything else?
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    what i did was get a bolt in tyre valve, drilled hole in a baked bean tin and inserted the tyre valve. insert the the bake bean tin were maf is. remove inlet pipe that goes to throttle body and plug with a bake bean tin. remove dump valve and plug both holes
