EM TuningVolks Autos
Results 1 to 12 of 12
    Jun 2011
    249
    Front Brakes/Rear Brakes
    I want to change my front and rear brakes/pads
    I was looking online and i found this website
    Brakes & Clutches / Euro Performance Car Parts
    could any one help me decide a pair of front and rear disk brakes and pads?
    Slotted are slotted into place and drilled are drilled into place am i correct or wrong? what are disadvantage and advantages of the both?
    i take it ferodo and brembo are the best ones out there?
    Thank you,
    A3 S Line 2.0 TDI Sportback - DSG
    BOSE, cruise control, bi-xenons, MFSW, Heated seats, paddle shifts, ipod connection
    19" Speedlines | Reverse camera | Eibach Sportline Springs | MY09 LED Tails | Eibach Spacers Front 10MM Rear 12MM | Pioneer HU | Private Plate | Tints | LED numberplate | Interior Light Kit
    Jun 2011
    249
    what setup are you guys currently running?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    "slotted" and "drilled" are referring additional machining processes that disks go thru.
    A slotted disk will have grooves or slots machined into the disks surface, a drilled disk will have holes drilled thru the disks surface.
    Personally i dont buy spangly disks. Grooved/slotted disks are often noisey and can eat thru your pads, drilled disks can crack and the holes can block up rendering them pointless.
    A set of decent quality standard plain disks from a good reputable manufacturer like mintex or pagid will do you just fine.
    Pads are where you want to spend your money (and avoid EBC), as well as replacing the fluid in the system with something better like ATE blue or Motul RBF600.
    TD5 Land Rover Defender build
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Slotted and drilled are the pattern on the disk they all go on the same way...drilled are weaker than slotted
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Mintex is not the company it used to be and is cheap chinese crap...
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Slotted, grooved & drilled are just different finishes to the discs, i.e drilled have holes in them etc...
    This is to give greater friction and allow heat to dissapate more quickly.
    I have Brembo Max grooved front discs and Ferodo DS2500 front pads - good combo but quite pricey.
    On the rear I have standard discs and Mintex pads - do the job and are quite cheap!..
    AUDI S3 QUATTRO 99-03 REAR BRAKE DISCS MINTEX PADS | eBay UK
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    Jun 2011
    249
    so budget disks, and good pads?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Not cheap but very good Black Diamond discs and Ferodo DS2500 pads, nice improvement over OEM
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Jun 2011
    249
    DS2500 pads front or both?
    Sep 2009
    741
    Not worth putting anything fancy on the rear to be honest, just go stock on the rear and youll have more £££££ for the fronts
    Mar 2011
    Exeter
    90
    Whats wrong with EBC pads?
    Nov 2008
    154
    Don't buy mintex! I had them on the rear of mine, the friction material disintegrated, they squeeled all the time, the metal back plate of the pads rusted so badley they jammed in the carriers and siezed. I doubt they were even on for a year!
    I use TRW now, the fronts have been on my car for about 3 years and were on when I bought it, still in brilliant condition. Got the rears from vwspares.co.uk.
