EM TuningBadger5
Results 1 to 18 of 18
    Jun 2011
    High Wycombe
    15
    Engine/exhaust rattle when letting off??
    Hi Guys,
    My first issue since buying my s3 a few weeks ago, last week my car started to make a rattling noise towards the front of the car when i let off from accelerating. could this be a problem with the exhaust downpipe or something like that? i have no idea about mechanics etc so if someone can point me in the right direction that'll be great.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Hi Daniel, most likely to be the heatshield that's vibrating
    Jun 2011
    High Wycombe
    15
    How can i stop it? its bloody annoying lol!
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    lol you'll have to go on a mad hunt to find what part is vibrating, does it do it if you rev it whilst stationary??
    Jun 2011
    High Wycombe
    15
    yeah it does when i rev it while stationery too, but only just started to do it last week whilst driving. its a hard noise to explain i'd like to get it sorted though.
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    i had this stupid rattle a couple of weeks ago, i thought it was my heat shield but it turned out my exhaust had moved over a little so it was vibrating off the underneath of the car pretty weird i have no idea how it had moved
    Jun 2011
    High Wycombe
    15
    well i did hit a rather deep pot hole the other day, only going at snails pace but it might of shifted something :S
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Did you ever sort the problem? I've just discovered I have the same problem but am worried it may be the cat.
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by Jonesy View Post
    I had it too, its was the heat shield after I clobbered it. I just pulled it off as it only had one spot weld holding it back on. I think most of them had corroded anyway and hitting it on something was the final nail in the coffin for it.
    Its only a shield on the underside of it to stop you setting fire to long grass when you park up so nothing major!
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I had this, was the heat shield too. Pulled it off! Problem solved!
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    REALLY lol looks like im ripping it of then
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Yeah easy job lol. Mine was only held on by two heavily corroded bolts!
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Typical car, couldn't get it off, 2 front bolts come off fairly easy but it seems the 2 rear and middle have fallen off and corroded to the heat shield and wont budge, was hitting with a mallet and tried chipping away at the corroded metal but no luck. Any tips?
    coatesy's Avatar
    Oct 2010
    1,901
    use a circular badger saw with a 7" weenie hammer :D
    beside been silly how about trying to heat it up with a blow torch or use a drill to get it off if you get what i mean
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Don't own a blowtorch or decent drill my friend works at a garage ill pop down his and get it done, i've had enough getting under the car this week.
    Thanks anyway
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    hit it harder
    S3Zek's Avatar
    Sep 2011
    407
    Grinder
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Quote Originally Posted by A3Tom View Post
    hit it harder
    and get crashed by car!! I dont trust my halfords jack and axle stands!
