Chris NottEM Tuning
Results 1 to 20 of 20
Thread: TB alignment
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,893
    TB alignment
    iv tryed to align my TB using vagcom, i used the version that welly posted up on here with the driver.
    so when it came down to doing it i followed the instructions :
    Cable-Throttle Engines
    Turn the key on but do not start the car.
    [Select]
    [01 - Engine]
    [Measuring Blocks - 08]
    Enter Group 098 (Note: Some SIMOS or Marelli ECU's use Group 001 such as ADY & AEE engines)
    [Go!]
    [Switch to basic settings]
    Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
    Click the [Switch to Meas. Blocks] button and you're all set.
    Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
    and then vagcom just says it cant do it, you dont have the full/registered version. what am i doing wrong or am i just been a plank with the same knowledge as a turd and missing something really simple ?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    You need the full version to the reset mate.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    The unregistered version is limited and you will need to buy a lisence or get somebody with the full version to do it for you, it is a very worthwile tool.....
    coatesy's Avatar
    Oct 2010
    1,893
    ah right i guess that makes sense thanks guys, is it best to buy the full version off ross tech's website or can it be bought from other places?
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,322
    you dont need a vagcom to re-align the throttle body.
    just disconect the battery then reconnet put key in and turn till all the lights are on the dash and dont touch any pedels should hear the throttle body moving about ie searching leave for 2mins turn the car off pull key out.
    put key back in turn car over TB done i have a vagcom and didnt need it to do this .
    coatesy's Avatar
    Oct 2010
    1,893
    ill give this ago tonight and see if this works, will it work with cable throttle ?
    Syvo's Avatar
    Jan 2011
    warrington
    1,322
    oo that is a question as im on dbw it worth a shot imo as the vagcom will only be able to calibrate the same as my method as they both going through the ecu
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by coatesy View Post
    No, it won't.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Syvo's Avatar
    Jan 2011
    warrington
    1,322
    does this only work with dbw welly?
    coatesy's Avatar
    Oct 2010
    1,893
    ah well thats pretty ghay.. i think i know somebody local that has full vagcom ill get them to do it
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    Doesnt even work with dbw, its a myth, theres a video on youtube showing a vagcom alignement and a battery disconnetced alignement, the battery one doesnt do anything.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    I thought as much....
    I've tried to do it the manual way in the past but the only time I've aligned it properly has been with vagcom.
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Syvo's Avatar
    Jan 2011
    warrington
    1,322
    carnt be that much of a myth as it alligned mine fine when had idel issues
    Mar 2011
    Warwickshire.
    246
    I was told by R-Tech that they aligned themselves after a clean. What happens if they are not aligned then... What effects would it have on the car?
    A3 quattro Sport
    Forge 007p Pipercross panel filter R-Tech stage one map (213BHP)
    Oil catch can mod, SIA delete, EGR valve delete. Forge EGR delete plate.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    Link to threads and said videos on youtube showing you what a battery disconnected jobby does and what a vag-com reset does:
    Why you should use vag-com to re-set the Throttle body - SEAT Cupra.net - SEAT Forum
    Syvo's Avatar
    Jan 2011
    warrington
    1,322
    i can see your point dani although if no access to the vag com the key in ignition will be fine.
    i did mine before getting the vcds lite so will have a dabble with the vcds lite at weekend and see if it make any difference.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    Vcds lite wont work mate, tried it and it says you need the full licence.
    Syvo's Avatar
    Jan 2011
    warrington
    1,322
    did mine last night with the vcds lite (i have the licence for the vcds lite) not alot to notice slightly better.
    rlc1985's Avatar
    top gear
    Aug 2010
    Coventry, United Kingdom, United Kingdom
    124
    Anyone got any more information on this?. Can you do it without the full version of vagcom manually for example disconnecting the battery and ecu or is it a myth?.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by rlc1985 View Post
    If you want it done, and done correctly, it needs to be done through VAG COM, or VCDS Lite (A registered copy of either). That is for BOTH DBW and non DBW.
    Homer Simpson
