Thinking about WMI... Just a few little questions
S3 Paul
Well-Known Member
Right, after going about as far as i can with the hybrid set up without wmi im not sure i will go big turbo any time soon if at all so... the ideal last step seems to be WMI of some kind...
I remember some people used "devils own" kit? Ive heard of aqua mist too...
Which is the kit to go for?
Is it a diy fit?
is the set up controlled by a boost preasure switch?
how much water do they get through?
Would plumbing it to use the screen wash bottle ( also used for the windows ) be a good idea? Was only thinking that as it has a low level warning system.
If the system runs out is the car still safe to use if used mainly off boost?
personally, avoid devils own.. They have been very unreliable, and I have dropped using them.
AEM is a good setup, as is Snow Performance, Labonte.... and there are others like Cooling Mist, Aquamist etc
I have personally used, Aquamist, Snow Performance (badgerwagen still runs this), Devils Own, and currently AEM
AEM ranks high on the value vs spec
