Chris NottEM Tuning
Results 1 to 8 of 8
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,458
    Tightening and loosening a hand brake cable.. How to please
    When i did the rear disc conversion i had to space the rear calipers out to fit the 330mm rear discs but as i did that its tightened the hand brake cable and i get the rear brakes binding just a tad.
    How do i loosen the cable?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    beachbuggy's Avatar
    Surrey
    1,741
    Remove the rear ashtray, the one behind the handbrake itself. Under there you will find 2 hex bolts attaching the cables to a Y connector with a rod going to the handbrake. If you need to adjust both calipers the same amount then just undo the rod bolt in the centre as this will realease equal tension, do this with the handbrake off, obviously don't do it on a hill . If you need to adjust one more than the other then undo the appropiate hex bolt on the relevant cable , left or right. ( this only normally needs to be done if you have a brake bias for the handbrake come up in the MOT)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,440
    I had to adjust the handbrake cable for my 308mm rear conversion, don't remember off the top of my head, but I'm sure you have to adjust the cables from under the car, then re-adjust from inside the car.
    Jun 2009
    Leeds
    3,458
    Just done the above and its still binding a bit so it may be a caliper.
    Another job for the weekend lol
    FOR SALE
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Are the levers returning back to their rest position on the calipers??
    Jun 2009
    Leeds
    3,458
    Not sure. Going to have a look this weekend and give it a good going over with copper grease.
    FOR SALE
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Ah, well i made a thread a while ago with Sharan helper springs, to assist the levers going back.. May save you the cost of a caliper.
    Jun 2011
    S.E. Melbourne/ Australia
    146
    I had the same problem when i fitted the ECS R1 kit on my TT.
    The problem on mine was that the cable didn't have enough slack so i had to cut part of the outer skin on them where the cable goes through the trailing arm to feed the cable through.
    If you cat the outer skin be carefull not to cat into the inner skin otherwise water will go into it and rust solid the cables.
    Hope it helps.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
