Sky InsuranceBadger5
Results 1 to 7 of 7
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    354
    thinking of upgrading to 16mm 4motion golf rear ARB??
    hey peeps,
    I have a Y reg AMK S3 and atm it has the standard rear ARB which according to the callipers is 15mm. I'm not wanting to go as high as a 19mm one as I have standard shocks and springs (dunno how old they are) and i don't want them to explode if the ARB unloads while cornering quickly, so I was thinking about upgrading to a 16mm one off a 4motion golf as I read somewhere that's an option.
    I'm basically wanting to check that the 4motion golf 16mm ARB will fit onto my car?
    also I take it I need to replace the drop links, brackets and bushes with ones for that bar as well?
    and how does it work with the bigger brackets for the bushes? do the holes just line up or does it need some creative adapting?
    or is it not worth it and should i just replace it with the standard one that's on it?
    i've had a look and I think the part numbers are:
    1J0 511 409 J - 16mm ARB
    1J0 505 466 C - connecting link
    N104 281 01 - hex bolts
    N102 861 02 - link to arb nut
    N010 236 6 - hex bolts mount bracket
    8A0 511 439 - arb bracket
    8D0 511 327 C - Rear Anti Roll Bar Bushes 16mm
    does that shopping list sound about right?
    so thoughts and suggestions on a postcard to ....... well me
    cheers muchly
    Ali
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    tbh its seems a pointless upgrade... a full R32 setup is a good/cheap upgrade if you are going to do it at all...
    <tuffty/>
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    £180 from vw for bar and bushes R32
    Nov 2008
    154
    I did this, my rear one was knackered. Just need bushes and the bar itself. Nothing else. ARB is about £45 and bushes about a fiver each from VW.
    ARB - 1J0511409J
    bush - 1J0511327B - the 8D0 bushes don't fit, I got them first and had to return them, ETKA is wrong on those as I found out.
    Made a nice difference to my car, reduced understeer and I am very pleased I did it.
    May 2010
    Bedford
    2,877
    Quote Originally Posted by Syvo View Post
    R32 bar is £108.86 inc vat and bushes are £3.95 inc vat each. So dunno where £180 comes from
    Even if you include drop links it only comes to £159quid inc vat.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    LukeTripod87's Avatar
    Apr 2009
    Kent
    325
    Not wanting to hijack this thread but I need to replace my front anti-roll bar. When I had my LCR I fitted an R32 front bar and it made so much more difference but is this principal different on the S3? Whats peoples thought on this? What have you found to be the best combination? Not really wanting to fork out on Neuspeed ones at £200 each! lol
    2010 S3 Sportback
    Miltek cat-back non res / soon to be wrapped!!.....
    **Message for parts enquiries in Kent**
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    354
    cheers guys
    i don't wanna go for the much bigger R32 ones really tbh
    i did just find this interesting thread Anyone tried aftermarket anti-roll bars for S3?
