Chris NottEM Tuning
Results 1 to 8 of 8
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Fitting an intank fuel pump to an S3
    Anyone have any tips for this job? I've heard its a bit difficult and may involve one of Audi's special tools to get the old pump out?!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    The only 'special' tool I am aware of is one to undo the plastic 'nut' on the top of the tank holding the assembly in... I use a pair of long nosed mole grips on my A4 when I changed the fuel sender...
    See here on mine when I wired the inline in...
    Would imagine its a complete unit so disconnect the fuel lines and wiring plug, unscrew the locking ring/nut thingy and pull the whole unit out... assuming this also has the fuel gauge sender/float assembly too then just need to carefully negotiate that out the hole... then replace with the new unit and bobs your actual uncle etc...
    <tuffty/>
    Westy's Avatar
    Dec 2008
    17,156
    It sounds like a pretty scary job messing about with the fuell lines
    I'll wait till I have the new unit in my hand to see what i'm up against.
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by W3STY View Post
    Its fine mate... there will be an initial leakage due to pressure but you can just loosen the feed going into the fuel rail first as this will mean less fuel potentially floating around in the car and they are push fittings and easy enough to remove... they may need gentle leverage but don't force them...
    The pipes are high enough not to syphon much if anything once off... its fiddly more than owt else tbh...
    <tuffty/>
    Jun 2011
    S.E. Melbourne/ Australia
    146
    Alternatively you can use a big flat screwdriver to unscrew the black ring, leveraging the screwdriver in the notches near the holes for the cover screws.
    Once you get that off you might need to prize off the roung lid, it's spring loaded.
    After you get that off you'll see the pump/swirl port, be carefull on unravel the flexi hoses.
    Then you have to take the round rubber seal off otherwise the swirl port won't go through.
    Then move the swirl port slightly to your left, you'll seethe other flexi hose goin to the otherside of the tank, pull it slightly towards to your left and you'll see a connector similar to the fuel filter, unclip it and let it hang there.
    Then near that flexi hose you also see an electrical connector for the other fuel sender, disconnect that as well.
    Then on the right back side of the swirl port there's another flexi hose hooked up to it, lift it up gently and pull it out.
    Hope i've been clear.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    Westy's Avatar
    Dec 2008
    17,156
    Cheers guys, I'm sure it'll be clearer once i'm half way through the job
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Battery disconection is a must....i have not done it on the s3 but ive done plenty of others, very straight forward, it some times can be a pain getting the angle right to clear the hole..
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Did this yesterday. So happy. No more hesitation or hard starts.
