Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By bhavin1986
Thread: Will this fit my A3?
    Apr 2011
    Gloucestershire
    248
    Reallyyy need my a3 lowered, its sitting at the moment on 18 inch rs4 and it looks like a monster truck not liking the look of the stance at all
    So i've read into it and see that i can't go low at all on the front without the arb being changed? but i can go low as possible on the back as it doesn't come standard with an arb anyway? I have an a3 1.6
    So, will this fit my a3?? Or does anyone know where i can get an TT arb from?
    Audi TT front arb VW / SEAT / SKODA anti roll bar | eBay UK
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    Yes. It will fit. I've just had a PM about this form another member. Here's a link to give you all the info you need:
    http://www.edition38.com/forums/inde...=326881&st=180
    If you're not already then sign up and you'll be able to see the thread.
    If not second hand then you can buy a new one from the dealers for around £90 all in.
    Hope that helps!
    17" BBS RS Reps, JOM Coilovers, TT ARB, Facelift Front & Rear Lights, Aero wipers, LEDs all round, 6000K HIDs, Blacked out Grill & Rings, De-wipered,
    12" 1000w FliTrap Sub, Colour Coded Lowers & Skirts...
    Apr 2011
    Gloucestershire
    248
    Quality cheers mate ! also, did you fit it yourself? was it hard?
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    Gave it to my mechanic to do but he didn't have a clue so I did it with him! We had use of a lift so was pretty easy.
    Subframe needs dropping to be able to get access though. Can be done on a drive on axle stands too. Not difficult if you know what your doing which my mechanic didn't since its not an OE part! But seeing as you have all the info from that thread on Edition it should be a straightforward.
    Apr 2011
    Gloucestershire
    248
    sadly that link doesnt work for me.
    [#10342] We could not determine which forum this topic is in.
    ill give it to my mechanic and see what he thinks, thx again.
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    You have to register on the site for it to work mate. It should be fine after you've registered and logged in.
    N4THW likes this.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    thats the same one i got on my A3 so it will fit.
    they are easy to fit if you got access to lift/pit
    i used my pit at work took around a hour to fit. have to drop the sub frame to get the old one out.
    if you use standard drop links your find they will be worn out in a very short space of time. i'm looking into ways of getting custom drop links made.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Thought I'd resurrect this thread for peace of mind. So do most people use the adjusterable drop links when doing this? As I'll be swapping my subframe for one from a cupra r that has the arb and rack on it.
    simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
