Volks AutosAH Fabrications
    Mar 2011
    Milton keynes
    150
    Location of relay for air compressor/conditioning...
    Could anyone give me any help as to the location of the air con relay/s please?
    My air cons not working,
    Ive had it regassed and checked for leaks.
    Theres 9vts to the compressor
    and the fuses look ok.
    on observation the clutch on the compressor isnt engaging.
    any suggestions welcome, Thanks
    A3 1.8t Quattro Sport!
    May 2011
    suffolk
    278
    same problem as me! check the 3 fuses on top of the battery. 30amp fuses. there are common to rattle around and end up burning/melting.
    let me know if you find an outcome please mate
    A3 Quattro T Sport.... Drilled and smoothed airbox - Red dogbone bush - 8k HID's - Stripped rear - N249 bypass - Bailey DV30
    colicabcadam
    under the plastic battery tray, it's held underneath the metal tray by 2 bolts, it has 2 leads going into it, one with 4 pings and the other with about 18
    colicabcadam
    PS - possible part number (depending on car) 1J0 919 506 K
