Sky InsuranceAH Fabrications
    Feb 2011
    Portugal
    161
    Wideband or non wideband lambda sensor????
    Hi, I want to know if my car as a wideband lambda sensor....
    I think that the wideband sensor have 6 wires in the plug, is this true???
    Can I see if it is wideband or not with VAG com?
    If it isn't wideband what should I do the read the correct AFR? Install a gauge with wideband sensor?
    I don't need nothing permanent it's just to tune...
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    what year/engine code is your car
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Feb 2011
    Portugal
    161
    year 2000, code APY
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    i have a feeling you have a narrowband, i think Welly's was and his S3 is APY.
    Alex S3 AMK
    Feb 2011
    Portugal
    161
    Quote Originally Posted by Cookstein View Post
    I have that feeling too....
    To install a AFR gauge do I have to put the windeband sensor in the downpipe? Can it be near or before the CAT? I have the Idea that it can be anywhere but....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    APY is not a wide band ECU soz...
    Ideally the wideband probe should somewhere close to where the OEM one is at the top...
    <tuffty/>
