EM TuningBadger5
Results 1 to 19 of 19
    Feb 2011
    southampton
    229
    idle problem fix
    i have been looking for what has been causing my idle problem , revs drop and come back up and only dose this on idle when i pull up at lights. i have tryed every thing to sort this problem
    like cleaned throttle body and reset with vagcom
    also cleaned injectors
    changed plugs
    change coil packs x4
    air filter
    fuel filter
    lambda sensor 1 as i had vagcom fault code
    and changed egt sensor as i had fault code.
    all codes gone and not come back
    and i found how to get the idle to stable all the time all i done is unpluged the egt sensor and took it for a drive for a few days and its fine all the time , but what damage will it do if i leave it unpluged
    will the car overfuel
    audi s3 2001 amk 210bhp, forge 007p
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Check the vac hoses underneath the inlet manifold, mine had the same problem and this was the cause.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Feb 2011
    southampton
    229
    Check them mate one had split so had to repair with silicone .
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    cant be good driving around with the EGT unplugged. I am pretty sure will overfuel and you will loose power too. Your not considering driving it from now on with the EGT unplugged are you? Does the EML light not come on with the EGT unplugged?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ive got the same problem. All vac lines replaced etc and nothings work! Dont think mines got a egt sensor as its a apy engine. Any ideas would be good!
    Feb 2011
    southampton
    229
    no pluged it back in and no eml light came on.
    Feb 2011
    southampton
    229
    If i hold the rev to 1000 rpm i get a popin from exhaust like its a slight miss fire i have tried disconnecting the maf and made no difference and brought on the tc light until i plug it in again
    Jan 2011
    N.Ireland
    149
    Faulty MAF?
    Feb 2011
    southampton
    229
    I un plug the maf made no difference
    beachbuggy's Avatar
    Surrey
    1,745
    I going to take a wild stab here as it sounds like you've already looked at the easy things.
    It sounds like especially with the poppin, that you have a leak in the inlet gasket or injector bungs. Drawing in etc air and causing the idle problems at misfires.
    Easy way to check and I used to use this on Dellorto carbs, is to spray WD40 around the inlet and injectors, covering well the area. If the problem goes away you have a leak from either the inlet gasket or injector bung, which are common to go.
    Worth a try.
    Feb 2011
    southampton
    229
    Good shout ill give that a try cheers ill order some new bungs and inlet gasket
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    After changing the lambda has the fault gone or is it still there
    Feb 2011
    southampton
    229
    Gone mate had a fault for egt sensor as well and new parts been fitted and no fault codes since part fitted
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    MAP sensor maybe??
    Feb 2011
    southampton
    229
    But will i get a fault code with map sensor if faulty
    beachbuggy's Avatar
    Surrey
    1,745
    And map sensor is for boost not vaccuum as you get at idle!
    Sep 2006
    Sunny Suffolk
    552
    Quote Originally Posted by karls s3 View Post
    Is that the plastic seat in the inlet manifold the injector seals sit in? Have you got part numbers and prices?
    Feb 2011
    southampton
    229
    my maf plug only has four pins and the sensor has 5 and the plastic around pins is a bit broken
    Mar 2010
    66
    Did you ever fix this? Im having exactly the same problem...
