Monster MotorsportVolks Autos
Results 1 to 8 of 8
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Heater blowing cold and temperature gauge reading too high
    Today I noticed my car crept up to just over 90 to about 100 degrees. It's warm so I didn't think much of it.
    Later on I saw it had gone to 105, this is as high as it read, so I thought I'd try and put the heaters on to take some heat out. The thing is, they blow cold.
    I have run the engine with the coolant cap off and squeezed the pipes to remove a possible airlock, but there doesn't seem to be one. The engine was running, and the gauge was at 90, so I put my finger in the coolant tank and it was warm, but definitely not 90!
    Car hasn't been using any coolant at all, and runs really nicely with no smoke so I'm confident it's not a headgasket, so what could it be?
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Aug 2010
    650
    coolant temp sender is a quick and cheap place to start. car has aircon so it works a bit differently i think.
    Genuine Audi Pink A3 1.8T, stage 1 remap. Genuine Audi bodykit and Reiger front bumper, 18's, JOM coillies down 50mmish, dewipered, debadged, 007P, K&N, Janspeed exhaust, Bose and a few other bits and bobs!
    WANTED: rubber mat which sits under ashtray in cubby hole
    drivers side wing mirror glass,
    bonnet in Devon area
    front brake discs for A3 1.8T
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Waterpump
    Aug 2010
    650
    Waterpump
    actually, now you said it, that makes a lot of sense.
    Jul 2009
    Cambridgeshire, United Kingdom
    427
    hmmmm, sandip, could this be my issue of running at about 100 degrees?
    Current
    Porsche Cayman S
    Gone but not forgotten
    Audi S3:Blueflame TBE; 3" blueflame downpipe; Forge 007p; jabbasport custom map; Badger 5 TIP v1, various bushes, N249 Bypass, Stack Boost Gauge, Junior GT Brembo brakes, tarox 2 part discs, DS2500's
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    thermostat stuck open ...and a failing waterpump
    Jul 2009
    427
    well the thermostat is about 2 years old but no guarantee its not messing up. If it was the water pump I would expect the temperature to go straight up. Mine just sits at about 99/100.
    Current
    Porsche Cayman S
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    So worst case at the moment is the waterpump? Is it safe to drive back about 30 miles at say 50mph? Obviously keeping an eye on the gauge.
    Cambelt is due anyway so will get it done tomorrow with some luck.
    8L IS DE BEST
