JMB RetrofitsVolks Autos
Results 1 to 10 of 10
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Anyone know how to open the headlights?
    I had my passenger headlight out last week when I was fitting my FMIC and I wanted to get to the bottom of the light bouncing around every time I hit a bump.
    It turns out that the little white stalk from the adjuster motor had come out of the holder on the back of the bulb fitting plate and the whole thing was swinging about like a dick in a bucket!
    Anywat I tried to open the headlight for easy access and couldn't so I tried to wiggle the motor arm into the holder and ended up breaking the holder
    I also need a new holder if anyone has a spare headlight unit kicking around PM me.
    Westy
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    you have to gently heat them in the oven and then you can prize them apart
    Westy's Avatar
    Dec 2008
    17,272
    Quote Originally Posted by Dane View Post
    Is there a recipe in Jamie Olivers latest book
    S3 Build Thread
    Dane's Avatar
    Cheltenham
    4,003
    honest guv,
    they are sealed, you need to warm the sealant to prize the lens away from the rear.
    a heat gun would do the same
    Westy's Avatar
    Dec 2008
    17,272
    honest guv,
    What about resealing them afterwards?
    S3 Build Thread
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    does the hot water trick work on these or oven best idea its true westy head lights in the oven.
    would be a good one if mrs asks whats for tea erm ......... head light lol
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    Quote Originally Posted by W3STY View Post
    heat them back up when put together as the seal is basically glue so when it goes cold it sets heat it up unsets
    Westy's Avatar
    Dec 2008
    17,272
    Does red wine go better with headlights or white
    S3 Build Thread
    Dane's Avatar
    Cheltenham
    4,003
    White for sure, as syvo says same process in reverse to seal them, but you may want to seal them again just in case.
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    lmao white as dane says
