Volks AutosBadger5
Results 1 to 13 of 13
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    coloivers gone lower?
    had my coilovers on for nearly a year and on the rear one side has gone lower / confused im guessing the shock could be knacered. or could it just adjust itself over time? really annoyed as it being lower on the left hand side it has caused my wheel to scrape on the arch!! litteraly RIM to ARCH
    CAR IS GONNA BE LOOKING SWEEEET :D
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    seems to be pretty common on this.
    i got one side higher then the other on the rear aswell
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Aug 2010
    652
    seems odd. damper has nothing to do with ride height. totally springs only. snapped coil? adjusters adjusted themselves? spring mount not seated properly?
    Genuine Audi Pink A3 1.8T, stage 1 remap. Genuine Audi bodykit and Reiger front bumper, 18's, JOM coillies down 50mmish, dewipered, debadged, 007P, K&N, Janspeed exhaust, Bose and a few other bits and bobs!
    WANTED: rubber mat which sits under ashtray in cubby hole
    drivers side wing mirror glass,
    bonnet in Devon area
    front brake discs for A3 1.8T
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    so annoyed spent a thousand on wheels with a stretch and the rim has hit the arch on the lower side. the normal side how ever is ok with people in it! what is best to do mate? dont even knwo how to adjust them
    Aug 2010
    652
    lay on the floor behind the car. you will hopefully see the springs on either side. at the very bottom of the spring is the adjuster. you will see the threaded bit with a big nut the bottom of the spring sits on. if you rotate the nut it will adjust the heght. you will have to jack up the corner of the car first to take the weight off. hopefully it will be obvious one you are under there....
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Surley it just a case of adjusting them so the car sits level? Part of the design of coilovers is so that you can adjust the individual heights on all 4 corners.
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Aug 2010
    652
    The Definitive Cheap Ebay Coilover Thread (Jamex) With" how to"guide
    third pic down. adjuster is the bright blue anodised bit
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    not aure will have to get it checked out ! mor emoney grrr
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,354
    why is it more money? Just do it yourself.....
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    +1
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Absolutely, coilovers are so easy to work with, especially on the back!
    Homer Simpson
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    will have a go guys. thanks will update if anything lol
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    do i adjust using that couiolver tool provided with the set?
