Volks AutosSky Insurance
Thread: Hot S3
    Essflee's Avatar
    Mar 2008
    2,007
    Hot S3
    Hi lads,
    Quick question, I got home tonight about 19.20, just been out to check the oil on the motor and after 2 hours it's still well hot, the car has been in the garage so out of any little breeze there might be, is that right or should it have cooled by now ? I know the 1.8T lump runs hot but jeeze...
    I was shocked as soon as I went to lift the bonnet as this was still very warm too,
    When I took the car out the garage this morning there was a puddle under it which I assume is from the aircon as it's been hot the last couple of days,
    I've checked the coolant and all seems rosey...
    Cheers.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yup totally normal.
    You want to remove the under bonnet heat proofing along with the rear rubber strip that runs along the engine bay, you should see the amount of heat that escapes.
    Chugger
    North Devon
    2,716
    its fairly warm outside so takes alot longer to disapeat the heat, especially with no airflow... if your temperture gauge is reading fine, you have nothing to worry about
    57 A3 2.0 TDI Sportback (140)
    Essflee's Avatar
    Mar 2008
    2,007
    Thought I'd check, after seeing the puddle this morning and then having an over cooked S3 I did start to wonder, cheers for the help lads
