VCDS Lite
dplovin
cheshire
just done a auto scan on my audi s3 2000 reg and it came up with these results couldnt go no further tho as ive not got a licence yet any idea peeps help much appreciated?......
VCDS-Lite Version: Release 1.1
Monday, 27 June 2011, 18:26:47.
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine Labels: Redir Fail!
Controller: 8L0 906 018 N
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 06435
VCID: 3A07B1EB3551
3 Faults Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
16795 - Shareware Version. To Decode all DTCs
P0411 - 35-10 - Please Register/Activate - Intermittent
17956 - Shareware Version. To Decode all DTCs
P1548 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18448
Shop #: WSC 06435
VCID: 3E0FBDFB2979
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-10 - Electric Circuit Failure - Intermittent
01423 - Shareware Version. To Decode all DTCs
27-10 - Please Register/Activate - Intermittent
Here you go fella... even though the shareware version doesn't show all the text for fault codes you can look them up here..
Category:Fault Codes - Ross-Tech Wiki
For example...
is... 16795/P0411/001041 - Ross-Tech Wiki
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Fuel Pump Relay (J17) faulty
  • Hoses/Pipes to/between Components faulty/clogged
  • Secondary Air Injection Pump (V101) faulty
  • Secondary Air Injection Pump Relay (J299) faulty
  • Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
  • Check Fuel Pump Relay (J17)
  • Check Hoses/Pipes to/between Components
    • Check Secondary Air Injection Hoses/Pipes for Carbonization
  • Check Secondary Air Injection Pump (V101)
  • Check Secondary Air Injection Pump Relay (J299)
  • Check Secondary Air Injection Solenoid Valve (N112)
...and 17956 - Shareware Version. To Decode all DTCs
is... 17956/P1548/005448 - Ross-Tech Wiki
17956/P1548/005448 - Boost Pressure Controle Valve (N75): Open Circuit
Possible Symptoms
  • Irregular behaviour
  • Loss of power
  • Limp mode
Possible Causes
  • Wiring and/or connections faulty (short circuit)
  • N75 faulty
Possible Solutions
  • Check wiring and connections
  • Check / Replace N75
Have you cleared them all to see if they come back?
<tuffty/>
Good stuff mate I'll check now buddy nice 1, wouldn't let me clear them mate but I did replace the n75 the other day as me old 1 was dud kept stuttering on boost hopefully clearing them an they dnt come back, I've just ordered one of those liquid things lol that sit in ya air vent Think u can clear the codes with them? Then gna get full licence for vcds
