Badger5Chris Nott
Thread: surge
    Aug 2010
    652
    surge
    would someone mind explaining what it is, how it feels and what causes it? I' just curious
    Genuine Audi Pink A3 1.8T, stage 1 remap. Genuine Audi bodykit and Reiger front bumper, 18's, JOM coillies down 50mmish, dewipered, debadged, 007P, K&N, Janspeed exhaust, Bose and a few other bits and bobs!
    WANTED: rubber mat which sits under ashtray in cubby hole
    drivers side wing mirror glass,
    bonnet in Devon area
    front brake discs for A3 1.8T
    beachbuggy's Avatar
    Surrey
    1,744
    Assume you mean compressor surge?
    Basically what happens is that air moves from a high pressure are to low pressure area. Under normal circumstances the exhaust turbine spins due to the exhaust flow which drives the compressor round and forces air into the inlet commonly know as boost.
    When you get surge, you get a reverse flow of the air. From the high pressure in the inlet pipe work back through the turbo into the tip.
    Dv's or blowoff valves over come this by releasing the pressure and stopping the compressor stalling. In a surge situation the compressor stalls and then reverses causing the exhaust turbine to the same. You get no air in the inlet a restricted exhaust flow and a bogged down engine response. in extreme situations the turbo shaft can snap due to the stress. A faulty dv or cracked vacuum feed will be the most probable cause of a surge.
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
