Chris NottSky Insurance
Page 1 of 3 123 LastLast
Results 1 to 40 of 94
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    DIY intercooler spray
    been bored looking for a cheap mod to do, so have made a intercooler sprayer
    as i don't have a rear wiper i have just used the connection off the screen wash bottle, the pipe closest to the back of the engine bay is for the rear wiper. tried to take a photo of it but too dark and hard to see.
    total cost was about a tenner
    total time was around a hour
    i used Vauxhall Insignia "fan sytle" washer jets. £4 something for Vauxhall
    i used 6mm fuel pipe picked up at local car shop was about £6 for 2 meters
    i ran the pipe from the motor to the intercooler, i made a little bracket from some old ally i had laying around and attached the washer jet to it
    ran some more pipe to the jet on the other side of the cooler
    once fixed in place tried to make sure it all works
    as they mist the water out it also covers both of the other rads in water, should hopefully help keep the temps down in hot weather
    back with bumper on. can't even see them
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    looks good but id loose the chicken wire
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Yeah defo lose the chicken pen at the bottom.
    You done any logs yet mate to see if it makes a difference?
    Feb 2011
    109
    Get a pressure switch so it only cuts in a set boost pressure, saves having to press a button.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    wire is only temp, just to help protect the cooler.
    looking for something better looking, like the RS4 stlye grille
    haven't had a chance to log any readings yet.
    i like the idea of a pressure switch tbh
    Feb 2011
    109
    I got mine off ebay a few years ago as my Impreza just had a switch on a timer, been trying to find it again but not having much luck. It's a small white switch which you can adjust to a preset level and then just plumb it in to the boost side of things. Can't see your pics yet as I'm VPN'ed in to work.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Excellent mate, I like it its a great idea. Get some logs done though. Obv on a really hot day itd be most effective.
    You can get sheets of the rs4 style grill mesh on ebay.
    mephisto's Avatar
    Oct 2004
    192
    Hmm interesting.. read this off another site
    If looking for even more efficiency than just washer fluid, one of the best is to mix up a 50/50 mix of water and regular rubbing alcohol. This mixture has been able to pull tremendous amounts of heat soak out of an intercooler in a very rapid amount of time.
    2009 S3 8P Phantom Black
    MODS : S3 Keyring
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by mephisto View Post
    LOL, or simply methanol.
    A different kind of water meth system.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    But a cheaper alternative and wont be as effective but should still yield gains.
    The old Evos used to have some sort of pressure switch that automatically sprayed to cooler when on full boost. I've searched around for something similar but struggling to find anything of any use.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by W3STY View Post
    You're right, they did indeed.
    I did find this: CryO2 Intercooler Sprayer Kit 080108 | Purchase DEI, CryO2, Ny-Trex, Boom Mat & SPA Turbo Products | Design Engineering, Inc. - Thermal Performance Products
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,264
    Bit pricey dude. I'd be up for a cheapo kit like the one above but I'd want a pressure switch instead of having to push a button.
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Bit pricey dude.
    Don't buy one, make one!
    Use one of these: Flojet 2.9 GPM 50 PSI Water Pump | eBay UK, the same jets as above, and some hosing. You could quite easily wire that to a push button so the pump fires up on demand.
    If you wanted to get really clever, you could also use on one these as well (Boost Pressure Switch - For Turbo Water Injection hobbs | eBay UK) to get it to switch on above a pre set boost level.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,264
    You're damn right i'm going to get really clever
    nice find mate.
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    nice find mate.
    LOL, it's basically the exact same config as my water meth, expect it's not spraying it into the intercooler pipework...
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,264
    It might be the solution for my small FMIC. I'll do some pikey investigation and see how cheap I can do this. Scrappy for spray jets, washer bottle and motor sounds like a plan
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,264
    S3 Build Thread
    mephisto's Avatar
    Oct 2004
    192
    Hmm guess you need to get it right incase you piss liquid across the tracks of your tyres right on a demanding corner. How much fakin methanol do you need to store in the car to make this a viable performance addon?!
    MODS : S3 Keyring
    Westy's Avatar
    Dec 2008
    17,264
    It's meant to be a fine mist so there shouldn't be enough to soak the tyres. Welly can tell you how much he gets through with his water meth system but I dont think it's too bad.
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'm planning to upgrade the pump on mine to a higher PSI, which will then use more. However currently, I don't use a huge amount. The S3 doesn't come on full whack boost until 4+ now meaning that everyday driving doesn't involve use of meth at all.
    My screenwash tank is 5.2 litres, that will last a tank of fuel easily.
    It's nice to see inlet temps drop below ambient outside temp when booting it in the summer! lol. Plus giving me about 110 octane fuel.
    This is also interesting: Basic Water Meth HOW TO | setting up meth injection
    Homer Simpson
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Would it be beneficial on a car that already has wmi like yours welly, but then you iats are probably low enough I can imagine.
    I dont see how spraying meth EXTERNALLY will cool more than water.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Meth evaporates faster than water basically, making it more efficient at removing heat. Not much - but it will a bit.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,264
    Another good little bit of info.
    The Scooby water bottles have 2 pumps in them, 1 for washers and 1 for the intercooler. The intercooler pump is set up the bottle a bit higher so that you cant empty the bottle completely and have none left to wash your wind screen.
    There's a few STI bottles and pumps on ebay. This might be a good idear if you can replace the Audi water bottle for this one?
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Linky....
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,264
    S3 Build Thread
  28. #27
    lukejenks's Avatar
    Nov 2010
    57
    I might do this later on, how big does the pipe need to be for the pump? I have loads of 4mm id pipe laying around
  29. #28
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by lukejenks View Post
    4mm ID should be somewhere handy.
    Homer Simpson
  30. #29
    Westy's Avatar
    Dec 2008
    17,264
    S3 Build Thread
  31. #30
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Good find westy lad!
    Good thing about external jets is its cheap and wont have to be mapped for like wmi
  32. #31
    Westy's Avatar
    Dec 2008
    17,264
    Pikey mods for FTW
    S3 Build Thread
  33. #32
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by jay1601 View Post
    Jay is there a seperate motor for the rear washer? I think it'll be a lot easier for me to utilise the rear washer hose as I hardly use the rear jet. It'll also mean I dont have to worry about finding somewhere to mount a new washer bottle.
    S3 Build Thread
  34. #33
    Feb 2011
    109
    My Impreza RA had a small seperate tank and pump to feed the sprays as standard. The newer RA's have a 7 litre the tank in the boot, it's controlled by the ecu these days, mine just had a button and a timer to begin with. My simtek ecu then controlled mine as it picked up off various senors, I had a 4 gallon tank in the boot like this:
    Fuel Tank Line Petrol Boat Outboard Motor Engine Gauge | eBay UK
    You could also use a micro switch on the throttle body rather than a boost pressure switch, you could start it at say 3/4 throttle so it's already spraying just before it stays to make any serious boost.
    And don't forget to fit none return valves to stop the water draining back to the tank.
  35. #34
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    The washer bag looks a really good idea but where would you fit it? The boot!
  36. #35
    Westy's Avatar
    Dec 2008
    17,264
    Yeah I gave up with the idea of fitting another bottle. If i went for a ful WMI kit I would mount the bottle in the spare wheel hole. As for a FMIC sprayer I think using the rear wiper pipe is the best bet as I hardly ever use the rear jet.
    S3 Build Thread
  37. #36
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    I built one of these on a gt4 many years ago. Combined it with a spal fan mounted to the IC to cool even more!
    '01 AMK, completely standard except for the Ambient Lighting Pack.
  38. #37
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Yeah but i dont think i would want to lose the rear jet.
    Im going to look into getting another pump and fitting like the sti's on the washer bottle, best of both worlds .
    gainey whats a spal fan?
  39. #38
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    It's just a brand of fan
  40. #39
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,321
    it's a fan, made by Spal
  41. #40
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Oryt oryt lol, thought it may have been something different, gits lol.
