Just no.
If you have got meth, a pissy intercooler spray off your washer bottle pump will be of no benefit. And if it gets to 96% humidity, by he time you add meth into the mix on a chemical level you will have all the cooling you need I am sure of it.
What are your IAT's? Is it an ongoing concern? Is there any reason why you feel like you want to do this?
I've been through this quite scientifically in other threads, but in short the energy transfer of the water evaporating is how the cooling works. To have a positive effect on your IAT's the water will have to be under HIGH pressure to create the smallest possible water particles. The surface area of the water that comes out of a washer pump just won't do the job anywhere near as well as you are expecting it to.
A PROPER intercooler sprayer is a great idea; but it's a lot more complex than the cobbled together **** originally posted in this thread. (no offense meant, though I know it will be taken.)
