Volks AutosChris Nott
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    hi guys, just did a VCDS scan on my 2003 S3 after my engine management light has been on and as title says i have the following code;
    I vaguely remember reading something about a revised coolant sensor which is intergrated as part of the coolant tank???
    could anyone else shed some light on this please?
    just did a quick search but couldnt find anything, cheers
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    There is a revised coolant temp sender/switch,(green one) but its not in the coolant bottle, the sensor in there is for the coolant level...
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    Thanks Dave, do you have a part number? Also where is it located?
