JMB RetrofitsSky Insurance
Results 1 to 14 of 14
Thread: S3 map sensor
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    S3 map sensor
    What is the standard one rated to i'e pressure and also is there a performance one out there
    Having worked on the odd Ford Cosworth they have a problem with the map sensor and they uprate them to a 3 bar so they can run more boost
    Now does the S3 suffer from the same problem?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Std one is a 2.5 bar (1.5bar less atmospheric pressure), I have heard of 3bar (2bar actual) being used but needs someone who knows how to scale it in the map as its still a 0-5v sensor... so it will under read unless scaled... may have a look at this myself sometime tbh as I think it helps with N75 control on high boost applications.
    <tuffty/>
    Jun 2009
    Leeds
    3,470
    Not sure i will need one so thought i may ask
    I'm not running my N75 only MBC, its still plugged in but not plumb in
    FOR SALE
    Jun 2011
    S.E. Melbourne/ Australia
    146
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    Jun 2009
    Leeds
    3,470
    Cheeky buggers charging that amount
    MAP MANIFOLD INTAKE PRESSURE SENSOR SAAB 9-3 0281002437 | eBay UK
    Same part number
    FOR SALE
    Pat
    Dec 2006
    512
    I know Andy @ LVS says mine wont go any higher than 1.5 bar due to map sensor.. something i need to look at now..
    Can you run a MBC inline with N75 valve???
    2002 S3, Project 400, New Build In Progress, I.E 2.0 stoker kit, Big Port AGU Head, Ferrea Valves retainers, springs etc, GT30 compact, Pagparts Manifold, AH Front Mount Version 2, Genesis 550cc Injectors, 044 Fuel pump in I.E Surge Tank, Revo Stage 3 Software, Porsche Brakes, work in progress
    Jun 2009
    Leeds
    3,470
    I was told the N75 and external waste gates don't work well together, I only have my plugged into the tip, electrical plugged in and thats it running a MBC if i need more boost as the waste gate is set at 24 psi
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,177
    Quote Originally Posted by Andrew@A.L.D View Post
    says who
    badgerwagen runs a std n75 on gt35, 44mm tial @ 35psi boost perfectly
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,177
    Quote Originally Posted by Pat View Post
    you can run higher, you just cant see the >2550mb pressures
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,470
    says who
    My bad, Just what i was told, I guess its all in the mapping then?
    FOR SALE
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Must admit thats all ive found in many hours searching lol. Maybe i need to search more in Bills direction for the relevant info...
    Audi S3 1.9 GT30....
    ....that is all
    RIP S3dave
    May 2004
    nr Glos
    7,177
    ask them to explain why they think this..
    external wastegate works on exactly the same principle as an internal one..
    What they may be talling you, whcih I have also said to you, is your actuator spring rate is way way way too high for any control... nothing left in resolution terms to control when you have a 25psi spring in it.. That sets your minimum boost level sky high.. ecu has nothing left to control.. So if thats what they meant, I 100% agree with them.
    in comparison, my GT35 ibiza runs stock n75 valve, controlled by my DTA S60 ecu, holds 35psi when its asked to, and a 44mm tial wg running in single port mode. My wastegate spring is 0.7bar so I have much more control range via ecu. If I need more holding shut pressure, I will just swap to using it in twin port mode.
    I would'nt want to map yours with a spring that high, thats for sure.
    www.badger5.biz
    bill@badger5.co.uk
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Whats your opinion on my 1 BAR spring Bill? Thats all i have for mine at the minute but surely dropping mine down to the same levels as yours (similar to oemish) will offer more control? Then just cap it off with a forge UNOS in parallel as tufty has to stop spike?
    I have been looking into electronic boost controllers but unsure if its worth it...
    Sorry for the hijack Andrew... all relative though i suppose
    ....that is all
    Jun 2009
    Leeds
    3,470
    Re set it to 1 bar then? This engine is still a learning curve for me
    FOR SALE
