Chris NottEM Tuning
Results 1 to 7 of 7
    Feb 2011
    southampton
    229
    what should the ign be on vag com o idle
    i have been using vag com yesterday and on 01 i was watching the rpm drop from 800 to 760 on idle
    and i had a look at ign timing and that seem to keep changing on idle its not stable it keeps going up and down , any one know what this should be or is it ok to keep going up and down.
    also the h02s are doing the same
    any ideas please
    audi s3 2001 amk 210bhp, forge 007p
    Feb 2011
    southampton
    229
    i cant believe know one knows this or even look at this on vagcom
    Jun 2003
    west yorkshire
    90
    Mine does the same it must just be the ecu keeping the idle steady
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I think it should be around 840..... im sure i will be corrected if wrong (standard ecu)
    Feb 2011
    southampton
    229
    is there any way i can adjust it using vagcom it seems to bad when warmed up
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    i think you can alter on unisettings, free download google it
    Feb 2011
    southampton
    229
    came across this so thought i would give it a try mine was set at 128 so took it up to 131 see what this dose then ..
    Ross-Tech: VAG-COM: VW MkIV Info
