JMB RetrofitsVolks Autos
Results 1 to 21 of 21
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Jumping when Idle...
    My S3 is jumping irregularly when idle, it has been doing it today at lights etc but only when in neutral... it has just had a service ...any idea's??
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Either the throttle needs a clean or it's the MAF.....
    Look out for me, i'm in Bolton too lol
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What do you mean by jumping? The car is or the rev counter is?
    If the rev counter is then mine always does it, cleaned tb, new maf etc and the revs still flutter!
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Quote Originally Posted by sandip View Post
    I will need to ring the garage on Monday again..it only came out on Friday!!
    I will is that your car in the pic?
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    The car is, only slightly and like I said irregularly like after 5 secs then maybe 10 secs...but when it does it you can really notice it...
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by S3MMA View Post
    Yeah that's mine, did you buy it from Bolton Audi?
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    No, from a small dealer..
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Ok, it's sounds like the throttle needs a clean i think, easy fix
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    I Hope so... I have read a few threads on here about DMF replacements!!
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Funnily enough my revs drop slighty but i can hear my DMF (rattles a bit), but it's been like that for a while, aslong as it ain't slipping i ain't touching it lol
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Fingers crossed then.. its something and nothing...
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    I'd say give it a throttle body clean and alignement with VCDS (Do you have that yet? It's very handy) and go from there before replacing things like the MAF.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sam how do you do a tb alignement again?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Dani,
    Take a look here:
    Throttle Body Alignment (TBA) - Ross-Tech Wiki)
    Drive-by-Wire (DBW) Engines using KW-1281
    (These are engines WITHOUT a physical cable between the accelerator and the throttle. Check to see if the engine speaks KW-1281 by looking in the top left of the Open Controller Screen Some examples of KW-1281 engine controllers are 2000+ Golf/GTI/Jetta/New Beetle/Audi TT 1.8T)
    Turn the key on but do not start the car.
    [Select]
    [01 - Engine]
    [Measuring Blocks - 08]
    Enter Group 060
    [Go!]
    [Switch to basic settings]
    Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
    [Switch to Meas. Blocks] button and you're all set.
    Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
    Or you can simply disconnect and reconnect the battery, but then you have to faff around with the clock and windows.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Cheers mate.
    The battery ways not mesnt tobe good, there was something in seatcupra.net about why you should use vagcom as thats the only way to correctly do it.
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Thanks everyone, I will have to get this done this week!
    S3-2003-BAM-MING BLUE-SILVER LEATHER
    Feb 2011
    15
    My car does this too is it bad? and blonde question but whats a DMF?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    DMF = Dual mass flywheel
    It could possibly be a vacuum leak get the garage to check pipes paying close attention to the pipes under the inlet manifold....
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Quote Originally Posted by fudwiza View Post
    Dual Mass fly wheel
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    It isn't doing it today, which is strange....it only does it now and again....
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Emma, check the vac pipe that runs underneath the inlet manifold these are notorios for splitting and case exactly this problem, I had it and the hopes was split, new hose no more irratic idle.
    Hope this heklps
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
