Now I would have said the pancake pipes are quite heavy unit hence why this;
Was cable-tied to the braket you can see which is used to support the SMIC I presume (before I cut it down due to how it looked previously). Won't go into it but basically I'm gonna reuse cable ties as a temporay measure to resupport it as it does wobble a lot and 'hang-down' as so to say due to the weight.
Now I'm just wondering is there a metal tubing you can purcahse which will replace the pancake pipe or some decent way of supporting this to replace the bracket you can see. I also want to change the boost pipe which connects the pancake pipe to the charge pipe. Seen these in the boost pipe kits you can buy (shown below in top left hand corner of picture) but because I'm not running SMIC two of the pipes would be useless;
Awesome - Forge Silicon Turbo Hose Kit 1.8T 150
Cheers for advice if any of that makes sense lol
