JMB RetrofitsBadger5
Results 1 to 9 of 9
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    replacement sump; original or pattern-part?
    Hey,
    I've got to replace the sump in my '02 TDI quattro as it's cracked and I'm pitched between an original from "them" at £119.06 inc vat, or this;
    AUDI A3 QUATTRO 1.6 1.9 WITH SENSOR HOLE OIL SUMP PAN | eBay UK
    does anybody have any experience which could sway me either way...?
    JimP
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Pattern parts ones are fine IMO. I have one sat at home which I must get on and fit.
    Go with the link, it looks fine.
    Homer Simpson
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    Really?
    did you source yours from the same place?
    Would you replace the 20 bolts round the edge at the same time?
    Sep 2010
    207
    I recently did mine. Wednesday in fact!
    I bought the hybrid sump of awesome gti.
    Abit expensive but its about 10mm shorter and has a steel bottom!
    Get them On awesome gti.
    Awesome - Hybrid 1.8T Shallow Sump Conversion Kit
    Thanks jordan
    A3 1.8t facelift 150p, milltek catback, forge 007p, gloss black roof, black s3 spoiler
    next on the list is some wietec coilies and eibach arbs front &rear
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    flashy stuff!
    £130 also!
    The webbed sides look cool!
    Did you replace all the bolts??
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    i don't think you need to replace the bolts... i certainly didn't when i cleaned out the sump and checked the pickup pipe, and it's been fine ever since... just make sure you use a good quality sealant... i used Hylomar Blue when i did mine as i had some left over from another job
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    ok Thanks for that...
    I'll probably start by cleaning out the bolts a couple times in advance...
    Got the oil and the filter now. So just to recap;
    no-one here is aware of any horrifying problems where they try to refit non-original sumps and the things don't match??
    (although as Welly says; it'll be fine)
    Sep 2010
    207
    Dont think so mate. Mine fitted perfectly. I would invest in a can of brake cleaner and a piece of 1500grit+ sandpaper.
    Makes cleaning the area of which the contact seal is going to be made a damn sight easier. Just take your time when fitting the new one. Make sure everything is clean. To make the best possible chance of sealing .
    I done mine 1st time and not a drip/leak anywhere!
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    thanks for your help...
    JimP
