Sky InsuranceVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 66
Like Tree1Likes
Thread: HELP! New MAF now = crazy overboost and backfire through inlet!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    *WARNING - ANGRY PRAWN*
    AAAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHHH!!!!!!!!!!!! !!!!!!!!
    OK, so now that I've got that bit over, I need help folks
    You may remember my thread a few weeks ago:
    New MAF not 100%? Likely? what would you do?
    So, i got my money back, and yesterday, I went to euro car parts, and got myself a MAF from them.
    Threw it on last night, and FECK. Complete opposite result.
    I let the car warm up, then took it for a drive.
    Foot down in 1st gear, and it instantly felt flat, yet the boost appeared to rise to 20psi or so in first, despite there being very little 'pull'
    into second, and foot down, and boost instantly rose to 24-25psi, with absolutely no power at all, it just felt totally flat, and then there was a HUGE backfire, which appeared to come from the inlet!
    I did a bit more testing, and found that it backfires hugely when it comes onto boost, it's overboosting to 25psi or so, then when it backfires, I'm fairly sure it's comming back through the inlet, because as it does it, my boost guage jumps off the scale at 30psi momentarily! Scary ****.
    Easing the throttle in to stop the spike it feels totally flat on boost, and the whole car hesitates and feels like it's surging back and forth, still boosting 23-24psi, and still backfiring randomly whilst on boost.
    what the feck is going on? Do the AGU engines have any kind of Fuel cut that I might be hitting?
    I stuck my old maf back in, and it's back to usual, running 16psi max, but feeling WAY quicker than it did on the new ECP maf that gave me the 25psi spikes.
    I thought at first it was because I've over tightened the wastegate arm in the past, but on actuator pressure it runs 6psi just as it should
    I don't get it guys First two mads gave me no extra boost at all, now this one has gone the otherway, into epic over boost, yet it feels flat as anything, so I'm sure it's pulling out all the timing.
    Will try and log it tonight and see where it's going wrong.
    Not happy at all
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    All i can think of is the ignition amp module breaking down from the new airflow..?
    Is your connector ok that goes into the MAF the pink insert can snap and cause the connectors inside to touch...
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Hmmmmmmmmmmmmmmm, that's not a bad shout Dave, connectors look fine, old maf in and the car drives perfectly.
    What gets me though, is, like I said in my last thread: with Plunkys MAF fitted the car runs amazingly, and runs the 22psi it was mapped for perfectly
    Backfire through the inlet is not something I've had on a 20vt before. mini has done it in the past, but that's always a timing issue.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    Yeah usually timing or sticking valves, weird one..
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Just a thought dude - what engine is Plunky's?
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Saw this and thought of you....
    Homer Simpson
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    what does it read g/s wise?
    backfire is lean backfire, so most likely dodgy maf again, and daft signal regarding airflow, for which the ecu's fueling against
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    AGU again, same engine, same ko3S, even the same exhaust and FMIC.
    Cheers Bill, I was hoping you would read this!
    I was thinking it could be a lean backfire, bit scary that, as it sounds like it's pretty risky running it at all.
    not logged it yet, will log this evening if I dare try it again.
    the odd thing is, my old MAF was (and still is) giving 187 g/s, which as I understand, is pretty epic flow for a ko3S, yet it'll only give me 16psi of boost. Plunkys maf in the car and I'm getting a really nice solid 22psi hold, and it's WAY quicker. Not had a chance to log with Plunkys yet.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,090
    Have you tried your MAF in Plunky's car ?? i'm sure i read on here somewhere only to buy MAF's off the stealers as the aftermarket ones seem very dubious,,, sure someone said they tried 4 replacements from GSF before they fianally went to Audi to get one that worked properly
    fran-s3 likes this.
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Prawn have you got N75J valve?
    A3 1.8t Quattro Sport!
    May 2011
    suffolk
    278
    rather than trying other peoples on yours.. try yours on other peoples!
    if theres plays up.. its 100% the maf.. if you put theres on yours and its fine... did you knock a wire that may be loose etc etc
    fran-s3's Avatar
    1,090
    Always buy a MAF from the stealers - one of the few items that it's worth spending the extra ££ for a genuine one.
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    I got a genuine Bosch one from TPS thats works fine
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    I got a genuine Bosch one from a seller in the UK:
    0 986 280 218 BOSCH MAF SENSOR 06A 906 461 M GENUINE | eBay UK
    I know the listing looks a bit pony but the item arrived boxed in a Bosch box as you'd expect and worked perfectly.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Not tried my maf on plunkys car yet, need to speak to him nicely!
    No n75J Sandip, all standard!
    I just don't get it, first few give me no boost, the this ******* sends it crazy!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,170
    I've had bad experiences with sensors from ECP before so anything elextrical I get from Audi.
    You'd better not tell Plunky that your new MAF might blow his car up shhhhh
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Problem is dude, a new MAF for mine at audi is MEGA money! trade price from TPS it's £231, so I think audi would be even more! (audi get their parts from TPS)
    Sadly they don't do exchange on these 4 wires MAFs, so it's outright only at crazy expense!
    Westy's Avatar
    Dec 2008
    17,170
    Oh yes you have told me before, my memory is dreadful!
    S3 Build Thread
    26,776
    I reiterate whats been said, always get a maf from audi, would never entertain from anyone else for this specific part, as quite simply I dont trust the mafs from others.
    May 2011
    suffolk
    278
    does it run without the maf connected?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    OK, did some testing tonight, and I THINK Bill has got it spot on, check out these logs:
    On my old dead maf, going full throttle around 3k, at about 4k I'm getting 140g/s+
    With the ECP maf, same road, 5 minutes later, going full throttle at 3k again, at around 4k I'm only getting between 85-105 g/s.
    Massive reduction in g/s at near identical RPM's, I couldn't risk taking the car to higher RPM's with the ECP maf as it felt SERIOUSLY rough.
    I guess, if the new MAF is reading really low, the car thinks it hasn't reached it's target load, so asks for loads more air to get where it wants to be, hence the low boost, and the lean misfire is because it's still fuelling from the MAF readings, so going mega lean?
    Thoughts most welcome!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Just looked back through some old logs, and it's always been around 140g/s at 4k in the past, so this new one giving ~100g/s at 4k is HUGELY under reading. I was also getting a 'maf signal too low' fault code.
    this HAS to be the problem surely?
    Pat
    Dec 2006
    512
    Andy from Lincoln VW spec has been out mapping my BT engine this week.. did afew runs then all of a sudden dash lit up like a xmas tree.. this was down to the MAF.. Been to tps and got a new gen one.. worth the extra pennies
    2002 S3, Project 400, New Build In Progress, I.E 2.0 stoker kit, Big Port AGU Head, Ferrea Valves retainers, springs etc, GT30 compact, Pagparts Manifold, AH Front Mount Version 2, Genesis 550cc Injectors, 044 Fuel pump in I.E Surge Tank, Revo Stage 3 Software, Porsche Brakes, work in progress
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    £230 though! That's mental money for a bloody maf :S
    26,776
    & how much you putting in your tank weekly :P still whining & get that maf baby fitted lol
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Quick vid showing the overboost and backfires. They seem really tame on the video, but are infact pretty violent in real life!
    I don't back of the throttle between the two pops in the second pull, it does that all on it's own.
    If I hold my foot down through the pops, the car pulls VERY sluggishly, and feels awful, surging back and forth, although the boost remains high:S
    YouTube - ‪A3 turbo overboost. Dead maf suspected‬‏
  28. #27
    Westy's Avatar
    Dec 2008
    17,170
    Ooo nice airflow readings, you might as well bring danes micra to the ring in September
    Seriously though MAFs are so god damn important on these cars and it does seem that there are a lot of bogus ones around.
    S3 Build Thread
  29. #28
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Your turbos working hard ini, 99.6 duty cycle throughout most of the rev range
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
  30. #29
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,360
    I had this once with ebay MAFs, only cure was to bite the bullet and buy one from the stealers. PS also cost me a turbo m as i "lost" a jubilee clipp during swap, and the turbo consumed it GULP
    Expensive MAF that was.....
  31. #30
    Westy's Avatar
    Dec 2008
    17,170
    Quote Originally Posted by Byzan A4 View Post
    Bloody hell. I bet you double check from now on.
    It's funny you should say this because when I fitted my B5 TIP last week on my brand new (only done 200 miles) turbo, one of the small jubalees had dropped into the bottom of the TIP! Luckily it was spotted before putting the top hose on
    S3 Build Thread
  32. #31
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    I have no idea what your car is running but £230 for a MAF? Surely not...what is it from?
  33. #32
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    maf looks faulty to me dude
    bill@badger5.co.uk
  34. #33
    Dane's Avatar
    Cheltenham
    3,991
    Quote Originally Posted by W3STY View Post
    you cheeky mofo, it's actually my brothers thanks
  35. #34
    Chugger
    North Devon
    2,716
    Don't be a tightarse mr iv got 3 cars
    57 A3 2.0 TDI Sportback (140)
  36. #35
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Cheeky *******! It's quicker in a straight line than a stage 1 S3, so we shall see :P
    Quote Originally Posted by JamJay View Post
    standard MAF for an AGU engine, very early 1.8T from 97/98, it runs ME3.8 ECU as opposed to ME7 in the newer cars, and has a 4 wire MAF instead of the 3 wire MAF in later cars. Audi/TPS no longer sell them as exchange items, and offer an outright sale only.
    Cheers Bill, I'm hoping so!
    Just been down to ECP with all my logs in hand, the bloke didn't question my results at all (and rightly so), So I've now got MAF # 4 to test tonight!
    if this fails, then I'll be paying the £230 for a new one from TPS
  37. #36
    Westy's Avatar
    Dec 2008
    17,170
    No we wont because I'll be stage 2 in 2 weeks time
    S3 Build Thread
  38. #37
    Mar 2008
    Oldham, Manchester
    1,090
    Hmmm i wonder what sort of MAF it is on my 99 AJQ engine ? hope it's not an expensive hard toget hold of one like yours Prawn.. I'll have to check that out this weekend..... when you say 4 wires do you mean going to the plug that plugs into the MAF of that it has 4 wires inside ???
  39. #38
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    yea, my AUM has a 3 wire maf, when you pull the plug there are 3 pins. 4 pins on the AGU maf
    Westy: I'll be dead keen to see just how much quicker your st2 S3 is than my St2 A3, will be very interesting!
  40. #39
    Westy's Avatar
    Dec 2008
    17,170
    I'd expect yours to be quicker over all due to your lack of weight. Straight line might be very close though.
    S3 Build Thread
  41. #40
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Point to point, considering the work, I'd be mortified if it wernt quicker :P mainly due to weight / brakes more than anything.
    Meh. who cares, so long as we enjoy them :D
    Will try and test maf tonight, but it's raining, and my lack of haldex prevents wet weather fun
