AH FabricationsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 52
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Can anyone help even audi failed
    My car has developed a overfueling problem!,over 2,000 revs fine!,under black smoke wrong idle!,it started overfuleing while away in holiday,so found a local audi delership to have a look after i checked most common faults!,they said it was a maf sensor so changed that still the same!,one coil pack looked black so changed that with a set of plugs,still the same,then changed temp sensor ,same!,have cleared fuel rail and fuel return pipe done compresion check!,only thing on diagnostics coming up is cylender 1 and 2!,but surely is due to fueling isue!.the car was mapped one month ago!,only thing i can think is a faulty ecu!,please help i hav spent £550 already!,car is booked back in with tuner race developments for friday!
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I would take it back to the Tuner... it could be a big vac leak...
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    i would guess at a big vac leak too if the problem is at its worst on idle
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Checked all the pipes!,one split one colapsed so changed!,also when you reset coads or take batterey of its fine for ten mins so its chucking fault up again!,cant be mechanical!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    could be a sticking injector?
    TD5 Land Rover Defender build
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    True thats what i thought!,but would it if the prob goes after reseting coads?,then chuck's them up again?
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    This would be likely.
    You said the only thing coming up on diag is cylinder 1 & 2. What about them?
    Fault codes would be useful.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    And did cleen them up!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by liquids3 View Post
    car is booked back in with turner race developments for friday!
    Hmmmm. Is this where you got it mapped in the first place?
    Homer Simpson
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Il try find fault coad
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    did this occur immediately after remapping or happened since?
    you drove past my place to get to theirs
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    No it was about a month afterwords!,plus a map eaither is there or not!,it would reset to standard settings if so!,oh is it yea im only bristol they are **** hot and so freindly up trd!,you'll have to pop up on friday no raceing though lol!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    he did what!! disgracefull lol
    Alex S3 AMK
    beachbuggy's Avatar
    Surrey
    1,727
    No ones mentioned it yet, but I'd say a faulty FPR could be the problem. They increase fuel pressure as boost rises, if the FPR is stuck then it could be raising the fuel pressure constantly and not just with boost as it should. Just try a known working one, also this would through up anything in vdcs either so it's more a try and see fix.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Good Shout..^^^
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Did cleen it out but if its stuck could be yes!,jst spent to much with trial n error!,il give it ago with a mates s3 worth a go!cheers!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Cookstein View Post
    I am keeping well quiet. See no evil, hear no evil, speak no evil.....
    Homer Simpson
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I still say some fault codes would be useful...
    Homer Simpson
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    try swapping the injectors around , clear the codes and if it comes back on the same cylinders then you know it's not your injectors..... it's something you can try thats not gonna cost you money
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Il have to use mates diagnostics to grab fault coads!,but within those cylenders new coils spark plugs and did swap and cleen injectors but not seen where the faught picks up again good point!,il try it and get fault coads!,cars ah like woman one minuite fine then they kick up faults!!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    this thread is useless without actual faultcodes dude
    bill@badger5.co.uk
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Wel will check all fault coads again tomoz!,but when we first checked them,back though vagcom,it came up with second lamda sensor,because its mapped out!changed for new one anyway,n75 deleat,should kick up fault due to n75 deleat!,and cylender 1,2!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Codes.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    cyl 1 and 2 what???
    jeez your hard work - lol
    bill@badger5.co.uk
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    cyl 1 and 2 what???
    It's impossible to help you mate as you have given no-one ANY specifics at all. Fault codes are the key to unlocking problems.
    'Cylinder 1 and 2 - intermittent eating toast and marmite for breakfast'?
    Homer Simpson
    Mar 2008
    Oldham, Manchester
    1,089
    "'Cylinder 1 and 2 - intermittent eating toast and marmite for breakfast'? "
    Eeeeewwwww no wonder it's fecked
  28. #27
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Fault coads. P0300/35/10. P0304/3510. P0302/35/10. P1240/3510. P1602/3510. Any help would be great!, injectors swaped was cylender 1 and 2 now 2 and 4 could injectors be the cause????
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
  29. #28
    beachbuggy's Avatar
    Surrey
    1,727
    17648
    P1240
    Cyl.4-Fuel Inj.Circ. Open Circ.
    18010
    P1602
    Power Supply (B+) Terminal 30 Low Voltage
    can be found here
    Audi Online Technical Library - Diagnostic Trouble Codes (DTC) Tables
    the other p0300 are misfires
    looks like a injector might be knackered
  30. #29
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Links for the correct codes:
    16684/P0300/000768 - Ross-Tech Wiki
    16688/P0304/000772 - Ross-Tech Wiki
    16686/P0302/000770 - Ross-Tech Wiki
    17648/P1240 - Ross-Tech Wiki
    18010/P1602/005634 - Ross-Tech Wiki
    The power supply one is where you have disconnected the battery.
    The others look to be injector related. I am guessing that you didn't clear the codes when you swapped the injectors, as that would really have helped diagnose.
    If you have swapped injectors from cylinders 4 and 2 around, then it will be one of those, looking at your codes. It's hard to say which as it retains the previous codes.
    Simple to diag though, if it misfires at idle, simply unplug the harness from those two injectors, and see which one makes no difference to running. That will be the one.
    Homer Simpson
  31. #30
    Mar 2008
    Oldham, Manchester
    1,089
    I still think it's the Marmite
  32. #31
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by 666markyboy View Post
    Marmite, the well known Octane booster..... lol.
    Homer Simpson
  33. #32
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    Bovril FTW!
  34. #33
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Dane View Post
    Bovril FTW!
    Ewwwww, wrong un!
    Homer Simpson
  35. #34
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    I did do that test to determin the coil went in the first place!,just checked again and coil four was gone,which is prob kicking cyl 2 out!,changed coil now drives alot better coil still fine,still black smoke so either need to burn carbon of more or somethink is making the coils go!,or something from what i have changed blew the coil?
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
  36. #35
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I'm sorry, and not wishing to be rude, but what the hell are you talking about?
    You have clearly go an injector issue which I would look to resolve first. Fault codes don't just come up for no reason.
    You have black smoke, a fuelling issue most likely - and a fault on an injector - I'd start there.
    Homer Simpson
  37. #36
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    True that why i said there must be another cause!,but surely an injector would either work or not work!,i.e blocked!,changed coil and they are now all acting the same!,i don't know im asking?,just sound weird!,has any1 else had this prob?
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
  38. #37
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    i would have thought that if it were coilpacks it would rear its ugly head when the engine is under load....not idle, you say its fine over 2000 rpm...
    people are suggesting injectors and your fault codes are also pointing towards injectors
    you swaped your injectors around and your fault codes jump with them...
    injectors were on cylinders 1&2 and thats where you had fault codes?
    You swap your dodgy injectors to cylinder 3&4 and now you have fault codes across all 4 cylinders.... thats probably because you didnt clear the fault codes from cylinders 1&2 before re-scanning
    injector, injector, injector, injector, injector, injector...so....i changed the coilpack and guess what.....oooh do tell
    Alex S3 AMK
  39. #38
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Thanks mate, I'm glad someone else sees it how I do.
    Homer Simpson
  40. #39
    Mar 2008
    Oldham, Manchester
    1,089
    And if it was a sticky injector it could be staying open longer than it should thus over fueling and giving you black smoke
  41. #40
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    That fair enough im not saying anyones wrong but have been told it could be fuel return pipe ect!,just trying to work it out did'nt think origianly injectors would do that!,does make sence though!,and the coil was'nt sparking on cyl 4!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
