AH FabricationsEM Tuning
Results 1 to 18 of 18
    Feb 2003
    107
    Question Clutch cylinder.. But which one?
    Hi guys...
    Yesterday my S3 clutch pedal started to behave funny.. When I start the car the pedal seems light to push with the bitting point about a 1cm from fully down... Also the pedal got stuck half way coming back up... Then after pumping slightly it came back to normal and the butting point is back half way (like normal)... Then today I had a similar issue after driving for a little while...
    What could this be, master or slave cylinder?
    If it the master whats the parts and labour expense?
    If it's the slave, what is the part and labour? Also might aswel change the clutch same time as the slave!
    Can anyone help....
    Feb 2003
    107
    Hi guys.. Quick update... The pedal likes to stick Hal way when I release it... But sorts it self out after pumping it again and again or by pulling it up... Does this sound like the master cylinder?
    Thanks guys
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    fluid dripping from gearbox to engine join?
    That will be slave IMHO Having tried the master to cure the self same problem twice to find it turned out to be the slave all the time
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    start with the master dude
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    Lizard-Racing's Avatar
    DTM
    Apr 2011
    Basingstoke
    124
    It will be the master most likely.
    2005 DTM|Quattro|Phantom black|Custom FMI|Autotech HPFP|Full stainless turbo back exhaust|AP Coilovers|Ultra Race strut brace|H & R ARBs|Forge 6 pot calipers|Projector HIDs|Multifunction steering wheel|Cruise control|Power fold mirrors|Black 19" Cades Berns|235/35 Toyo Proxes
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    thats wot i thought then it turned out to be the slave and then i thought to hell with it ill have helix paddle clutch and light flywheel
    Feb 2003
    107
    Thanks guys..
    How hards it 2change the master cylinder? Does anyone know if the pagid master cylinder is good from eurocarparts?
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    i think its a bit of a pig in the way of you got strip a few bits out to get to it, i think its more akward than anything????
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,085
    I hope for your sake that it's the master cylinder! I've had two slave cylinders go on two cars this year, and both times it's leaked fluid onto the clutch and caused it to slip! Nightmare. Have had to remove the gearbox and change a whole clutch for the sake of a £40 slave that takes 10 mins to fit!
    Feb 2003
    107
    Guys with the slave cylinder is it better to get it from audi or german and Swedish be good enough for the job?
    Does anyone know any garages who work good on audi in west London?
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    I have mine done at AMD Essex they do it in about 5 hours I think
    Feb 2003
    107
    Arron how much do amd charge for clutch and slave cylinder?
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    785 clutch n fly wheel ( ouch )
    360 for 6 hours labour
    Duno how much the slave was ???
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by AARON77 View Post
    Plus the vat
    Feb 2003
    107
    My S3 has only done 60k... Flywheel should be ok?
    Feb 2003
    107
    Just looked under the car noticed some yellow fluid between the engine and gearbox... It is the slave cylinder... Hopefully my RAC maintenance and breakdown warranty will pay for the slave cylinder (as it states in the t&c)...
    I will just pay for the clutch separate.... Anyone uses RAC warranty before?
    Apr 2004
    12,372
    the irratating thing is, the slave itself is around £30, Its the labour that kills it
    Feb 2003
    107
    Finally got the car back from the dealers. Flywheel, Slave Cylinder and clutch changed... It was the slave cylinder leaking....
    Got other issue now... Have posted it in a new post... Got vibrations after 200rpm under load...
Tags for this Thread
