AH FabricationsEM Tuning
Results 1 to 8 of 8
Thread: Temp sender
    G60DAN's Avatar
    Cornwall
    321
    Temp sender
    Hello all
    I'm hoping that someone can tell me where the temp sender is located on the engine as I think it's not working as my S3 has started to use a lot of fuel.
    Feb 2011
    southampton
    229
    on passanger side near air box and engine its pushed into coolant hose there should be green plug.
    audi s3 2001 amk 210bhp, forge 007p
    G60DAN's Avatar
    Cornwall
    321
    Thanks for that will have a look
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Make sure the systems not pressurised before you do it, lol, so take the coolant cap off first.
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    does the ECU use the temp sender for fuelling? or is it just the DIS that uses it so you know when its warmed up?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Believe it uses it to seen when its warmed up etc. Doesnt the ecu use the something in the fuel tank or sumet like that.
    G60DAN's Avatar
    Cornwall
    321
    It uses the temp sender to see when the car is warm it's like driving round with the choke on if it's not working.
    Alex C's Avatar
    Lizard, Cornwall
    2,606
    ah, thanks
    Alex S3 AMK
