    S3 Paul's Avatar
    Oct 2006
    2,759
    Looking to fit 19mm rear anti roll bar... what other bits to complete the rear?
    After feeling for a while that when driven hard the rear of my car is way too "soggy" ive been looking into what roll bar to fit. Im going to go with the R32 rear ,
    My car has Koni coilovers ,
    Kw adjustable rear tie arms.
    Will soon have the poly bushed front wishbones fitted
    The brakes are finaly sorted and ive recently fitted the blue haldex controler.
    Are there and bush's on the rear to look at?
    Is it worth fitting poly Bushes in the non ajustable tie arms?
    Poly anti roll bar bushes?
    Im not looking to spoil completely the day to day drive as the roads to work are not the best , I just want it to feel more controled and complete.
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    Poly bush the ARB , and you may as well do the other tie arms, not sure if there will be much difference there though, as the original are very stiff (I have a set if you are doing them)
    trailing arm bushes will stiffen it up..
