JMB RetrofitsBadger5
    S3 Paul's Avatar
    Oct 2006
    2,764
    Might fit another Jetex filter... Help please
    After fitting my first BIG jetex filter i said i was un happy with the noise ( strangely sounded like a corsa with no airbox ) off boost.
    I was later told ( after selling the filter ) that the noise was down to the filter not having and sort of bracket to suport it?
    If this is the case can people who have them fitted please give me a few ideas ( and pictures) as to how they suported it?
    Noggy Blue 2001 S3
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,360
    I used an alloy joiner on mine to space it out from the MAF about 3-4''.
    What i did, was butt the filter up against the inner wing, with the edge sitting under the little bracket that holds the standard airbox.
    To get it to sit tight, I then pulled the intake back so the whole lot was under a bit of tension, and did up the clips. Mine doesn't move at all, and also doesn't sound like a corsa!
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Custom heat shield for under £20
    A3tell's Avatar
    Jun 2009
    essex
    239
    i also made a heat sheild out of alloy!! there is a big thread on here with a step by step of how to make it.
    search for:- diy heat sheild for under £20. you should find it!
