Volks AutosAH Fabrications
Page 1 of 3 123 LastLast
Results 1 to 40 of 82
Like Tree4Likes
Thread: Turbo Chatter
    sam4191's Avatar
    If In doubt, Flat out!
    Feb 2009
    Highcliffe, Dorset
    399
    Turbo Chatter
    hi guys.
    Been running my car for 4 months now. Since I fitted silicon TIP and Cone filter, have enjoyed the turbo chattering away. Only in the last week have I come to realise (due to reading) that it is probably damaging the turbo. The turbo is only 4 months old (4k miles), so need to sort this.
    The DV that is on it currently looks like a Forge 007 jobbie, but has 'Turbo dynamics' written on it.
    What should I do? Try a new Forge 007?
    Any help greatly appreciated!
    Thanks!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    Your dump valve might not be working properly, you could check it works and has the right spring or setting on it, or easiest would be to get 007p.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Had a Polo GTI in the other day that had this issue... replaced the DV and was still doing it.. checked for fault codes and there seems there was an issue with the operation of the N249 so I ran a bypass and the fault code didn't come back...
    I would scan the ECU for fault codes in the first instance as it maybe that there is another reason why you are getting chatter
    For anyone who is unsure of what this noise is, if you rev the engine (into the 5k region) you should hear a chu chu chu type noise rather than a shusssss type noise as the DV dumps... the chu chu chu noise is compressor stall... this is bad and can destroy the trubo... Bill has some pictures of a customers hybrid K03 turbo that ate itself after an APR DV went bad and he was getting this noise... he only ran the car for a little while before changing to a Forge 007p but it was enough (it seems) to have weakened the turbo into eventually destroying itself... it should be said he uses the car as a track day car but it still shows this is a bad thing to have...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Can be split/ leaky pipes from the n75/actuator area
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,284
    The N249 is a total mine field of hose that loves to split.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    I had a really bad chatter when i fitted my dv30, After a i service the dv it was almost gone but i could still here it a bit.
    It turned out that the hose that goes on top of the DV was getting squashed when i put the engine cover back on.
    After changing the straight fitting on the DV for an elbowed one, the chatter disappeared
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Mine has always had a little wastgate flutter, only at spool up,
    after about 3000rpm it doesn't do it
    it's an APY and totally standard, is this normal?
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by bazil View Post
    There's so many different things that can cause fluttering. Mine was fluttering when cold on boost up, I replaced every hose in the boost circuit and it still did it. Just had my turbo stripped and found the culprit:
    Now this is an extreme case. 9 out of 10 are eithe DV or a split hose somewhere.
    S3 Build Thread
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Ah crap, I thought it was normal, it's done it since I got the car in 2003 and never got worse and it's covered 70,000 miles in my ownership,
    Westy's Avatar
    Dec 2008
    17,284
    Well I'm not trying to sh!t you up but mine has done it since the day I bought the car and it had covered 125K miles. I thought that it was just the turbine blades that were a bit blunt causing the issue but the whole housing turned out to be cracked. The turbo was still bosting to its mapped 21PSI but just wasn't producing the air flow it should have been.
    S3 Build Thread
    sam4191's Avatar
    Feb 2009
    Highcliffe, Dorset
    399
    Ah. ok. Will check all the hoses tomorrow then, will also order up a 007. Then at least that is ruled out!
    I have bypassed the N249, and all the pipes to that are ok.
    Will check out tomorrow and report back.
    As said... mine also only seems to do it under 3k.
    Thanks for the replies guys!
    shanejess
    its called scare mongering, if any one has a big open cone and a 007 you will here a chatter on gearchange or letting of throttle when under load, its normal dont worry not stall lol, mine chatters my turbo wont distruct itself or snap a conrod lol.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,920
    Have had it for donkeys,cars still rapid.....ish
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by shanejess View Post
    Like I said it depends what flutter you have. No scare mongering. My flutter was on boosting up not when letting off, and it only did it when the turbo was cold. I now know that this was because of a massive crack through the wastegate housing which closed when the turbo heated up and the metal expanded.
    The DV diverting its air back into the system should not be a fluttering noise but more of a whoosh.
    S3 Build Thread
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    No, no it isn't scare mongering, so kindly refrain from giving out bloody awful advice.
    I've got 007P's, and Jetex cones on both my 1.8T's, and a flutter, is not normal.
    an atmospheric style 'woosh' is normal, and that's the DV venting back into the TIP< which is then heard through the air filter.
    Any 'flutter' heard is due to the DV not opening enough, and is compressor stall.
    Answer me this:
    If the DV opened in a single movement, why would you get a 'flutter' sound from it?
    You wouldn't, you'd get a single air release sound for the duration the valve remained open.
    Flutter is compressor stall, and it'll kill the turbo.
    The only time you might get some flutter is when backing off really slowly, sometimes if you back off slowly, there isnt enough vacuum generated in the inlet to open the DV (if you've got a strong spring in there) fully, so a wave of pressure still goes back to the turbo giving a small flutter, that's not a problem, but a flutter when letting off from full throttle, is bad news.
    Ko3 and ko4 turbos have gay little bearings, and they won't last if you allow them to run like this long term.....
    AARON77, Westy and S3Lol like this.
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Mine never flutters on higher boost or from full throttle, only at low engine speed like upto 3000 rpm,
    Westy's Avatar
    Dec 2008
    17,284
    Is it when letting off the throttle or as the turbo is coming on boost?
    S3 Build Thread
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    mine dont flutter either ????
    i have badger tip n k&n cone filter??????
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Quote Originally Posted by Westle View Post
    It's always on lift off, never on boost or spool up.
    Westy's Avatar
    Dec 2008
    17,284
    First port of call is to check that the DV isn't sticking.
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Fluttering on boost is normally surge... very much doubt you have that...
    Do you have the std DV or has it been changed for an aftermarket one like a Forge? the std DV's are prone to failure and the diaphragm splits... this will cause fluttering...
    As Prawn has said, you can get a little flutter from partially letting off the throttle (not fully closing the throttle) due to lack of vacuum lifting the DV but this tends to be very minimal...
    <tuffty/>
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Standard DV so I'll check that out, To be honest it's probably it's original.
    I'll also need to plumb in a boost gauge and see what the boost levels are and how it's behaving,
    sorry to the OP if I've hijacked the thread
    sam4191's Avatar
    Feb 2009
    Highcliffe, Dorset
    399
    No worries dude. Its all learning! I need to be clued up on this turbo business, so its all helping
    RIP S3dave
    May 2004
    nr Glos
    7,199
    flutter as in chirpy noise like cossies used to make or a woosh?
    chirp/flutter is compressor stalling, and a non-functioning recirc dv = bad news for the turbos lifespan
    exhibit (A) - a hybrid k03 which destroyed itself shortly after its APR DV failed, causing chirpy noises, whilst on high boost on track...
    Remembering the internals of a k03 hybrid are in fact a k04
    Be Carefull.
    Shanejess's advise is as misleading as usual
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    Holy sh1t that's bad? What happens do bearings just give up? Making the shaft and wheels eat themselves?
    Westy's Avatar
    Dec 2008
    17,284
    I bet hardly anyone on here checks/services their DV either?!
    S3 Build Thread
  28. #27
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    There are so many things I would love to say in response to this post, however I shall refrain due to not wanting to get banned from ASN.
    Homer Simpson
  29. #28
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    Not my Bosch one no
  30. #29
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Every service I service the DV as well. Takes 10 mins and is good for piece of mind.
    Guide for it is here as I can't be arsed to type one...
    Servicing on the 007 dump valve - SEAT Cupra.net - SEAT Forum
    Homer Simpson
  31. #30
    RIP S3dave
    May 2004
    nr Glos
    7,199
    its an extreme example, but one caused by a non-functional DV... DV's were fitted by manufacturers to prevent them from seeing these high surge pressures. Chirpy sounds, although they sound cool, are not in the turbo's best interest.
    www.badger5.biz
    bill@badger5.co.uk
  32. #31
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,920
    Just checked mine and the top seal is split,the two seals inside are intact though.
  33. #32
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by voorhees View Post
    What DV is that Jase?
    S3 Build Thread
  34. #33
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,920
    Forge 007p but it has the tube on the side rather than top
  35. #34
    Westy's Avatar
    Dec 2008
    17,284
    What seal has split then? Any pics?
    S3 Build Thread
  36. #35
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    A friend of mine had a turbocharged clio, which was fitted with a recirc valve (not sure which, but it was an Audi fitment valve, it may even have been a 710N), and it would chatter but only when the engine was revved at idle or being driven gently. I can only imagine this is because while the turbo would have been spinning, it wouldnt have been creating much in the way of positive boost, and the DV simply didnt open.
    When actually driving the car and generating proper boost, it would dump just fine with the expected woosh, but light throttle pootling around town type driving would cause it to flutter, as would revving the engine up in neutral.
    I know some DV's have different spring ratings, and i suspect that a stiff spring in the DV would stop it opening at low pressures as ive described, and could cause the flutter?
    TD5 Land Rover Defender build
  37. #36
    sam4191's Avatar
    Feb 2009
    Highcliffe, Dorset
    399
    Right. Just been out and removed the dv. Followed the guide that welly Put up and the piston drops a bit when holding the niPple to create vacuum, but doesn't drop completely. There was alot of filing type metal dust in there, so cleaned that out. It has a silver spring. The outside looks just like a forge one, but has AMD turbo dynamics written on it. As far as the vacuum pipes go, they all look pretty good to be honest, though want to renew it all anyway. Can I get away with a forge service kit and new spring, or is it a case of might as well try a 007p?
  38. #37
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Too stiff a spring will stop it opening, simples. Green is fine for most S3 applications IMO.
    Homer Simpson
  39. #38
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by sam4191 View Post
    Save yourself some money on testing, buy an OEM one and use that to test. It is a LOT less money and will certainly do the job for testing purposes.
    Homer Simpson
  40. #39
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,920
    no pics,it was the one on the top it was in two,the two in the chamber are okay I've ordered the repair kit
  41. #40
    RIP S3dave
    May 2004
    nr Glos
    7,199
    vacuum opens a DV not boost
    www.badger5.biz
    bill@badger5.co.uk
