EM TuningChris Nott
Results 1 to 27 of 27
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Audi S4 Maf, Badger,Tuffty,Welly
    I see that wellys and Tufftys Mafs are maxing out with there set up
    I see your looking at a S4 maf but which one will you be trying out?
    N/A 4.2L or 2.7 BI Turbo one
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Cant you use the s3 maf but in the 4 inch tube and scale the sensor parameters to suit in the map?
    Audi S3 1.9 GT30....
    ....that is all
    Jun 2009
    Leeds
    3,472
    Not sure the s4 has a different sensor? Young the size of the tube is a option just looking into it before mapping
    FOR SALE
    Jun 2009
    Leeds
    3,472
    done a bit of research and here is what i found on the net
    S3 has a 2.80 bore
    2.7 bi turbo is said to be 3.00 bore
    4.2 N/A has a 3.5 outer bore not sure what ID it has but looks like it will be over 3.00
    FOR SALE
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    I'm going to see the guy building that big turbo S3 in my thread at the weekend so I'll ask which he used on his GT2871R build. I think he may be going MAFless on the new build.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    beachbuggy's Avatar
    Surrey
    1,746
    RS4 mafs are good for 550g/s or 600bhp. So unless you pan on going over that you can use the RS4 Maf ok,
    RIP S3dave
    May 2004
    nr Glos
    7,187
    0280218038 maf i used to un on my ibiza (max'd it) measures 77mm ID 86mm OD
    I cant for the life of me remember what model it came off.. anyone match the numbers to the donor? - S4 maybe?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Application List
    Vehicle
    Year
    CC
    Engine Code
    AUDI - A6 2.7 T Feb 1999 to Jan 2005 2671 AJK AUDI - A6 2.7 T Feb 1999 to Jan 2005 2671 AJK AUDI - A6 Avant 2.7 T Feb 1999 to Jan 2005 2671 AJK AUDI - A6 Avant 2.7 T Feb 1999 to Jan 2005 2671 AJK AUDI - A6 Avant 2.7 T quattro Jun 1999 to Aug 2001 2671 AJK AUDI - A6 Avant 2.7 T quattro Jun 1999 to Aug 2001 2671 AJK AUDI - A6 Avant 2.7 T quattro Jun 1999 to Aug 2001 2671 AZA AUDI - A6 Avant 2.7 T quattro Jun 1999 to Aug 2001 2671 AZA AUDI - A6 2.7 T quattro Jun 1999 to Aug 2001 2671 AJK AUDI - A6 2.7 T quattro Jun 1999 to Aug 2001 2671 AJK AUDI - A4 S4 quattro Sep 1997 to Nov 2000 2671 AGB AUDI - A4 S4 quattro Sep 1997 to Nov 2000 2671 AGB AUDI - A4 S4 quattro Sep 1997 to Nov 2000 2671 AZB AUDI - A4 S4 quattro Sep 1997 to Nov 2000 2671 AZB AUDI - A4 Avant S4 quattro Apr 1998 to Jul 2001 2671 AGB AUDI - A4 Avant S4 quattro Apr 1998 to Jul 2001 2671 AGB AUDI - A4 Avant S4 quattro Apr 1998 to Jul 2001 2671 AZB AUDI - A4 Avant S4 quattro Apr 1998 to Jul 2001 2671 AZB
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Probably an RS4 MAF here - part number 077 133 471 K
    Well, dependant on what the deal is with the scaling on mine...
    Homer Simpson
    Jun 2009
    Leeds
    3,472
    Quote Originally Posted by beachbuggy View Post
    2.7 or 4.2 RS4 MAF?
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,187
    My S6 MAF's enormous..
    BUT - remember the idle g/s from a small displacement engine on a supersize maf will be pretty low signal, and I wonder how stable it will be
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,472
    I think a RS4 2.7 one will be man enough for my 2.1 GTX3076r
    FOR SALE
    Jun 2009
    Leeds
    3,472
    Just got one of these now, just need the silicone hose but i can't find any hose that has a 86mm ID for the maf? is that OD correct bill, may wait till i get it
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,187
    86mm OD - rechecked yes
    I would confirm the sensor with your chosen mapper first... so he can map with it
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,472
    One last thing
    Is it the sensor thats the restriction or the housing ?
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,187
    http://badger-5.com/bin/published-bosch-sensor-data.pdf
    read page 54/55 on maf's and how they work
    sensor is a temperature device.. metal film resistor. it measures velocity, which is calculated into mass airflow by knowing the internal diameter of the tube it sits in.
    same mass air flow thru larger tube, the velocity slows down.. so maf sensor would ouput a lower voltage.. aka ecu would think a lesser amount of mass airflow went in.. Hence ask your mapper before adding something they may not wish to accomodate
    www.badger5.biz
    bill@badger5.co.uk
    Nov 2011
    Finland
    131
    So if I max out the S4 maf (337 g/s?) the tune would be based on map signal?
    Would I benefit anything if I use RS4 maf over maxed out S4 maf?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Quote Originally Posted by BuuBBa View Post
    MAP runs out at 1.5bar so don't rely on that.. benefit of using an RS4 MAF is that the ECU and VCDS will see true airflow... however its not as simple as just fitting and RS4 MAF...
    Map will need rescaling and compensation maps fine tuned on a steady state dyno to tweak fuelling on part throttle loads for a start...
    <tuffty/>
    Jun 2009
    Leeds
    3,472
    Welly is still on a s3 maf and he's making 445 bhp
    I did run a s4 maff but now run a rs4 maf due to my gtx 4 in intake and power level of my engine spec
    FOR SALE
    BENJAMIN's Avatar
    Mar 2011
    472
    I'm running a S4 2.7t maf housing with S3 sensor. It's reading around 280g/s and made 405.8bhp on Saturday. The idle is good!
    Nov 2011
    Finland
    131
    Ofcourse the car will be tuned for the custom setup..
    Oh I did not know about the 2.5bar MAP...
    Is there any 3bar MAP that would fit straight to original position? Or would it be easier to plug the hole and take pressure from manifold to external map?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    What the MAP sensor sees is irrelevant in context as it won't affect the engines ability to make power or run boost higher than 1.5bar... the 2550mb limit is hard coded to the maps binary and cannot be changed without decompiling the machine code...
    Using an external MAP sensor serves no purpose...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Quote Originally Posted by BENJAMIN View Post
    Not scaled then lol... S4 MAF tube should be good for 337gs (420 odd hp)... earlier S4's had Bosch MAF's and later ones used Hitachi... the data in the maps are different scaling wise and there is also an offset value to watch out for..
    AMK/BAM S3 maf tube runs out (in VCDS) at 292.58... APY max earlier...
    <tuffty/>
    Nov 2011
    Finland
    131
    Okay, I thought its the sensor that has 2.5bar limit.
    So professional tuner can make the ECU understand MAP boost pressure over 1.5bar?
    Or how the ECU can be tuned if the MAF and MAP is maxed out?
    BENJAMIN's Avatar
    Mar 2011
    472
    <tuffty/>
    Nope not scaled, was running an S3 maf and 550's. Now running an S4 maf and 630's, Afr looks good and drives really well. Could do with a custom mapping session but as far as an off the shelf file goes its really good.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    The ECU interpolates data based on what it can see... I don't confess to fully understanding everything about it but it shouldn't be an issue if your tuner knows what they are doing with ME7 ECU's...
    All that matters
    I really need to get mine finished lol...
    <tuffty/>
  28. #27
    Nov 2011
    Finland
    131
    Thanks tuffty, once again!
    I havent decided who tunes the car cause dont even have all the parts yet.. But at least one tuner (in Finland) has managed to get 600hp with stock ECU from 1.8t, so he might be the one..
