Sky InsuranceEM Tuning
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Wishbone rear bushes
    Planning a big suspension overhall soon - got new rear arms and bushes and was planning on doing top mounts and wishbones at the same time.
    I was going to replace the rear bush in the front wishbone with the TT none-voided bushes but dont know if these can be pushed in without the use of a press. Anyone know?
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    I would recommend pressing them, however I did fit a set once using a bench vice....
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,321
    oxyacetaline or how ever you spell it, i burnt mine out and pushed the new ones in using a vice, i used powerflex bushes as they were two piece bushes so nice an easy to fit
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,452
    Vice will work, just hard to get it straight. Which is important as the top side needs to sit flush with the wishbone
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Very good point.
    Homer Simpson
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Thanks all. Press it is then. Will remove them DIY and cycle them to the local garage to press in
