Results 1 to 12 of 12
    A3 1.8t Quattro Sport!
    May 2011
    suffolk
    278
    N249 removal help please.. (pic enclosed)
    hey people, have read over the guide many times! i know it says a trained chimp could do it.. the thing that your going to find hard to beleive is...
    im a fully trained main dealer mechanic! lol
    but i just cant make sense of the pictures and descriptions! lol
    i have a 2000 A3 t sport quattro. engine code AJQ.
    can someone please take the time to explain what i need, what needs to go where etc.
    thanks alot.
    jamie
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    I don't think our engine has one mate... mine too is an AJQ,,,, someone who knows better will no doubt be along soon though and put you straight one way or another
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    May 2011
    suffolk
    278
    from what i can figure out its the little box with the connector on it thats just above the intake pipe on the picture? and the big box above number 4 coilpack can be removed? i may be wrong though!
    what mods do you personaly find work best on our engine? cheers
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    the little box above the TIP with the electrical connection is the N75 valve which controls boost. You will have an N249 vale else you wouldnt have the vacuum reservoir i.e. the black box thing sitting on top of coil pack #4
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    there is a black plastic engine cover that sits in front of the inlet manifold, under that is a metal plate. Have you checked if the N249 valve is under that plate?
    Alex S3 AMK
    May 2011
    suffolk
    278
    thanks for the reply. be right back will go check now
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    guide to bypass the n249 valve - uk-mkivs
    try on there although the whole point in a n249 is to stop the car over boosting
    May 2011
    suffolk
    278
    this?
    so would you say its worth me doing? i have read it makes the boost more responsive too? plus im pretty sure i have a leak from it and would rather lose it than pay or new pipes lol
    cheers, jamie
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    i would go with the oil catch can before this as there are far more pipe's under the inlet that cause boost leaks.
    i can't comment on throttle response although i have read people do see a difference and some dont there has been no proven gains to what i have seen over removing this the oil catch can helps with keeping crap out of the engine.
    Guide - How to fit a catch can and simplify the PCV system
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    yeah, i think thats it, you can see it sitting under that metal plate to the right of the dip stick in the pic. I havent done it personally but i would say that given the number of people who have done and there are no bad reports from it i would say go for it. Its supposed to sharben throttle response as well as reduce the likelyhood of boost leaks. It does remove one method the ECU has of cutting boost when it feels like it, but the ECU has other methods to do this so its redundant anyway....
    Alex S3 AMK
    May 2011
    suffolk
    278
    great thanks alot! i have a catch can at work so thats definatly worth doing!
    one last question about the n249 one.. on the picture on the link you gave me. the pink colour pipe, goes from the dv into a tee peice, into the pressure reg, then where does the last part of the pipe go?
    sorry for the probably stupid questions!
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    he has used the line that goes to the fuel pressure regulator (FPR) as his boost/vacuum source, so he has just T'd into it. If you just run a pipe from the inlet manifold (where the N249 valve is currently plumbed in) and run it to the top of your DV then thats it. Remember to leave the N249 plugged in electrically. All the other gubbins can be cut out.
    Alex S3 AMK
