AH FabricationsJMB Retrofits
Results 1 to 10 of 10
Thread: TT arb noise!?
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    Angry TT arb noise!?
    Just fitted the TT arb and I don't know if it's that as I've fitted new poly dog mount n new top mount but there's a deep ping noise when I turn on uneven ground. Any one know what this is or had similar noise. I'm using standard a3 droplinks and bushes.... Very deep ping sound when I reverse too
    CAR IS GONNA BE LOOKING SWEEEET :D
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    No issues here mate. You checked your droplinks are in one piece?
    17" BBS RS Reps, JOM Coilovers, TT ARB, Facelift Front & Rear Lights, Aero wipers, LEDs all round, 6000K HIDs, Blacked out Grill & Rings, De-wipered,
    12" 1000w FliTrap Sub, Colour Coded Lowers & Skirts...
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    I'm considering adjustable ones. But how do they help?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,083
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by audi-tk View Post
    They don't help at all, they are actually longer than the standard ones if you run them with the locknuts fitted so don't give any more clerance than standard unless you unsafely run them with no lock nuts.
    And the bushes are so weak they break down after a few thousand miles.
    I'd suggest looking at worn top mounts front and rear. Get the car jacked up and spin the driveshafts and check for scoring/rubbing.
    I quite often say I'm going to do things.
    Then never do them.
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    Does it sometimes when I full lock. Not sure . Don't know weather to take it to a garage as it probably won't make the noise then grr
    Aug 2010
    1,540
    which side is the noise? sounds like a tight front top mount to me if the spring is winding up and releasing (pinging noise) as your turning lock to lock.
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    Can't tell mate all I can here is a deep ping sound when I go over in even ground . A drive way when I turn on full lock or sometimes even when I reverse :/ tight? If so that could wear out quicker? Defo sounds like arb as can feel it on bottom of car slightly.very hard to explain ...
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    Have you checked the track rod ends? Turn the car from lock to lock whilst stationary and have a listen then.
    Then never do them.
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    Hi mate I'll have a look the tracking is alot if that could be the problem? When arms were off haven't had it tracked yet!
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    NOISE FIXED. the tracking was badly out. got it laser alighned and now the noise has not come back. very strange...
