Chris NottAH Fabrications
Results 1 to 7 of 7
Thread: What is this??
    Jan 2011
    77
    What is this??
    What is the black box with the tubes going into it?, 2 of the pipes seem to be loose but don't want to touch them until I know what they are
    Scott
    beachbuggy's Avatar
    Surrey
    1,742
    To do with the fuel system and vaccum to draw vapours out.
    The pipes will be loose, they are not actually loose as the fixtures are tight they just wobble a little so don't worry.
    Jan 2011
    77
    the one on the rightlooks as though i could pull it out and has ribbed white bit showing
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    That's the charcoal canister. Part of the fuel vapour system as stated above.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    they should be wobbly. whatever you do dont brake the pipes. it STINKS of fuel otherwise.
    Jan 2011
    77
    thanks guys
    scott
    May 2006
    Lancs
    211
    The one on the right runs round the coolant bottle into the charcoal filter. Mine was knackered at both ends so I swapped it for a bit of rubber, no more petrol pong.
